On other abit mobos with LEDs e.g. AW9D-MAX you can adjust the light settings both in the BIOS & in the Windows uGuru GUI.
Have a look & see if the IN9 is the same.
I just built my new rig with this mobo. and everytime I start my computer it give me a 8.E post code and then it turns the computer. That code is check cpu fan speed. I have my cpu watercooled so theres no fan of course, but I can't disable the cpu fan monitoring in the bios, unless I missed something. Is any one else having this problem.
After a talk with Abit tech support and Thier RMA dept. I have decide to RMA the vendor. According to Abit they have no RMA stock right now. So at this point they don't have any repaired/refurbed boards. The vendor I bought mine from (eWiz.com) has agreed to send me a new board on my RMA provided that: 1. I have not damaged it and 2. it is actually malfunctioning. Keeping my fingers crossed and looking forward to using this Abit board.
BTW: the post LED is invaluable feature. I have been looking at cheaper backup boards to use just in case mine gets tied in up in the system, but it wasn't till i started looking that I realized what a rare feature this is. It helped immensely when I was trouble shooting my problem. My 2 cents.
-Scotty
Dan,
Considering my previous 3 builds were completely problem free. This is the first time I've have to do any real trouble-shooting while getting a system up. Since my problem was intermittent I would know exactly when it happened. I would get a post code telling me that my cmos jumper was shorted and it didn't always happen at the same time in the boot up sequence, sometimes it happened at the very beginning and wouldn't boot, sometimes I would get all the way to installing my OS before it would crash and post the Cmos jumper error code. It wasn't a matter of wondering what the problem was, I could look at my post LED and immediately tell what the problem was when my system would lock up (of course I am making the assumption that the LED is posting the correct error msg).
edit: I have disk with a full system image on it of my current windows install which I will put aside with the p5w dh just in case I need to revert back to that mobo...
Well - I got my board.. but I had no time to even pull it out of the shipping box last night.. so busy and tired. whew.. I'm going to wait until my NB and SB coolers get in until I start prepping it anyways... I'll be taking lots of pics when I do start work on it... Prolly Weds or Thursday night. Although I have heard a lot of complaints about issues with this board, the over-all sense seems to be that this mobo is the most problem free 680i offering to date.. but there is the sense that the bios is a little immature.. oh well. given the extra time they took with this board I think that's kind of bad, but oh well.. life goes on. and newer bioses should start rolling out soon.. I am sure Abit wants to make this as good a launch as possible and I still have very high hopes that this will be a great stable well performing board.. hope hope hope![]()
the only issue I first encountered when was setting up my system was of a Maxtor drive I have not being detected correctly or hanging the system on boot
the fix to that was changing the jumper in the maxtor from 1.5 to 3.0 settings
after that i havent even encountered one single problem...
the board has been rock solid.
probably I am one of the lucky few?
True... do you have anything OC'd yet? I am shooting for 440*8 if I can on this board.. or 450*8 if my cpu will allow it.also going to try for 1T timings on my ballistix.. they should do it.. not at 3-3-3-9 tho.. maybe 4-4-4-12.
Problem comes in the moment you raise something.![]()
You need to specify what you're running.![]()
I am running the following
E6600 @ 3.0 ghz
I am not an expert at overclocking so I used the easy settings of the board. I just selected Linked oC and increased the FSB to 1300 mhz.. well thats what the board says.. and no problems at all
just increasing the FSB it did the other things automatically
the rest of the system is Corsair Dominator 2 gig of ram 8500
X-fi Fatal1ty gamer edition
raptor x
maxtor 500 gigs
sapphire X1900 XTX
and I havent encountered any problems.. which keeps me wondering why all the complains.. are people picky or what
I finally opened my shipping box this morning.. just to make sure I was shipped the right mobo.. yep. mmmmmmm.. it looks nice.
Dude,
I was thinking the exact same thing. The last Abit I ran was the BH6 as well. That thing was a rock, I think I still have it somewhere. Used it with my PII 400. I used that motherboard based on the Skinny Rig they built in the 1998 (or was it 1999?) maximum PC.
Thought about an AB9 QuadGT?As another long time Abit user who is now running the Abit AB9 Pro with enough success to make your discontinued Core 2 overclocking list at FSB 403 I too am looking to upgrade. As you well know abit's boards have not gotten good reviews of late. Your folks just tore up my AB9-Pro drilling it a new ......... I like the board but actually I especially like Abit's Guru.
Yeah - I have a Tuniq also.. it's a great cooler! Aside from it's ginormous size, I think it's an ideal cpu air cooler...(this coming from a long time water cooling fan)... currently mine is mounted to the air goes in the right side and out the left side.. I am going to shift that so it goes in the bottom, then out the top, then have both my 120mm fans as exhaust and my rear 120mm as intake... it should blow right over the PWM and cpu area.. so I don't think I will need an extra fan. whew. I hope this all works.
lol, we're going to have twin systems.. or just about![]()
