Are those windows 7 Ultimate versions RTM? They have dates of 8-24-2009 as being the last time it was updated. The other versions of win 7 have a date of 10-22-2009 or later.
everything is listed twice... the old ones with the aug dates and the N versions are october. whatever N means...
oh, i think ive heard that before. sounds like a EU revision... but doesnt that mean you just install wmp yourself and its peaches and cream?
so... its 200 win7 installs thenim just kidding around, you dont have a life if you use 200 computers
I think the N version is without internet explorer or media player.
god damn... this doesnt apply to msdnaa keys does it? if it does, im not doing it right![]()
whats the real draw of WHS though? the way you can add a bunch of disks together as a single drive? because ive been using vista for my server now, and i gotta admit its really nice... im so familiar with it that it seems WHS might just be more trouble then its worth...
Windows 7 went RTM in August.
Windows 7 retail launched this month.
RTM=Released to Manufacture's
I am running a WHS box and I like it. I have 8 disks on a controller card. The stuff I don't want to loose has folder duplication enabled.
Also, you can install a client on your desktop(s) or laptop(s), it will back up your data, and, in the event of a disk failure, you can do a restore. I have not done a restore. I have used the built-in backup client.
What I like about the file sharing capabilities, is, if you have a user account for each machine, say, in a household with a family, you can set folder permissions for each user. I also setup a dummy user1 account for when guests come over.
I use my whs mainly for storage.
:/ i do easy file backups as it is, and vista can assign individual users to folders...
can WHS run regular apps like orb and skype? i guess i should really play with it and see what its all about, i just dont see how it will make my server any better then it already is...
Will a TV Tuner card work in WHS?
~Yes and no. There is no WHS drivers for tuner cards, however, you can use 2003 drivers if they are supported by your tuner. WHS is simply a 2003 operating system with the WHS application overlay. If it supports 2003 you should have no problems.
Subscribe to technet and get all MS software, think its 10 licence for Windows 7 ultimate
http://technet.microsoft.com/en-gb/default.aspx
well worth it imo, the price for me is just a little more than buying one retail boxed windows 7 ultimate, this way I get the library plus 10 ultimate keys
(wish i'd known about this sooner, hence the post)
Will a windows home server 32bit work with windows 7 64bit machines?
Do you need to renew your technet subscription each year? meaning if you sign up this year and not sign up the following year, do your keys become invalid at that point?
Is anyone else only able to download Windows 7 @ 56k speeds on technet? I haven't gotten higher than 7kb/s and it usually kicks my download after like 300mb. I had no problem downloading Vista or XP @ 500kb/s
Yes I only can get 56k speeds and it kicks my download after a while.
We're sorry, the following error(s) have occurred:
The promotion code entered is no longer valid. If you have another promotion code, please enter it here.
