Thank you one time again for your reply Fritingo.
My English is poor so this maybe the reason I can't understand this:
"But...page 4-13 in the user manual for the X9SAE has the following: "Boot Graphics Adapter Priority. Use the feature to select the graphics controller to be used as the primary boot device. The options are Slot 6 VGA, Offboard, and Onboard." So it does look like you can select. Would be very odd if you couldn't. Traditionally on boards with integrated video chips (in the old days) or boards that support CPUs with GPUs (currently), there have always been BIOS settings allowing you to select which one is active."
...because It seems that You say it to show that perhaps this board is an exception to this your following statement:
"That's odd. Traditionally, you can't use both a CPU GPU and an offboard card at the same time. Not familiar with any modern board that allows that. If you really need that capability, get two offboard cards."
...but instead it seems to me only a confirmation.
...unless "primary boot device" means a secondary device is contemplated...
