- Oct 29, 2000
Several months ago, I bought a case fan that was on sale at MicroCenter. It's called an "AKUST Reversible 12CM Speed Control Fan.
I didn't open it until yesterday, and when I did, I found it had a rather odd connector. I'm used to 4 pin fans looking like the connector on the left, with the blue wire for the PWM. This fan has a wider slot fit, and a yellow wire where I was expecting the blue PWM wire.
The box it came in speaks about a "Fan Controller Bracket" which presumably is supposed to be in the box, but is missing.
Do you guys think this is a PWM Fan? Would it be safe to connect to a 4pin PWM header?
If not, you think it is safe to use it as a 3 pin fan?
I appreciate any input.
Thanks,
Matt
Thanks,
Matt
