octoberasian
- Oct 13, 2007
Valve tests the shit out of everything. If this controller ends up sucking, you will NEVER KNOW IT because Valve will never let you touch or buy one.
Also, people complaining about lack of buttons. If you look at the spec it seems like the trackpads are clickable in the four separate up/down/left/right regions. there are your buttons.
Yup, both trackpads are clickable like D-pads. So, this was probably a combination of both an analog stick and a D-pad at the same time.
The buttons on either side of the touchscreen in the middle are your typical 4-buttons on a gamepad, or the right trackpad can be used as one as well. I can't tell if there are L and R trigger buttons on this.
