Rydawg5143
- Apr 22, 2008
EOC tracks everyone's stats. and those say you folded for the [H]
Then yes, that is me.
the truly dedicated have machines that do nothing but fold and go days on end without being touched.
I guess I'm no longer that dedicated, I'd use it for what you built it for and don't shut folding down except for gaming. Todays computers have way more power than they need to cruise the internet and watch some hulu. Sure there will be minor point hit, but folding shouldn't interfere with these.
pausing should pick up right where it left off.
What name do you fold under?I just set up F@H a couple of days ago to try and see what my i7 970 can do. I've completed several WU's but I never show up on the stats page. Any advice?
His team number is correct, scroll down to the bottom of his stats page.I think your team # is wrong.....it should be 33
Are you sure they completed successfully, the log file for the client is called FAHlog.txt. Take a look at it or paste it here, embedded inI've watched it do several WU's. Probably about 5. I wanted to make sure it was up and working properly before I switched to bigadv.
flags, and we'll try to help.
Are you sure they completed successfully, the log file for the client is called FAHlog.txt. Take a look at it or paste it here, embedded inCode:flags, and we'll try to help.[/QUOTE] I'll do that when I get home this evening. Edit: It looks like they are completing properly. Might just be slow to update. It said I did 2 more WU's today while I was at work and the machine wasn't even on...
Once you finish your 10 SMP units and switch to bigadv, about 35K PPD.What kind of PPD averages should I be seeing for my box?
i7 970 @ 3.8ghz
6gb RAM
Double post go!
Moved to seprate thread not sure how long I'll have access to this system;
My ego must know however when will I be able to reg with the team?
Up the vcore and vtt, F@H is one of the hardest stability testing programs out there
How high should I go? My vcore is 1.31 and my vtt(qpi/dram) is 1.31. I'm running an asus p6t deluxe.
With FAH GPU tracker how do I set bigadv? Also is it worth it on my current setup?
core i3 520 @4.2
16gigs ram
2x gts250
