So...basically you guys are saying that if I like video games, I should pick up SS2? lol
If you have a friggin' pulse at all you need to buy this game or you hate and kill puppy dogs, too.
Get it?
Get it?![]()
So i take it you're enjoying it so far?
Thats not a new engine, that video was uploaded after the ninja patch was released and its just showing it off. (Widescreen, 1080p, 32bit color)
So to answer your question, yes, the GOG version is 2.4, which was the last version of the ninja patch. You may still want to load the mods to make it look even better.
How critical is load order on mods?
Well, you can't mess up the game if you are using the mod manager, but from my experience it's better to load the bug fixing mods before any texture/model mod. Depending on the order you activate the mods in the manager, you might see more/less conflicts. You kinda have to play with it.
As for the cfg question, maybe cam_ext.cfg file?
That was the main file to edit when 2.4 came out. Ah, here is that old post: http://hardforum.com/showthread.php?p=1039178489#post1039178489
So we've got all that right now with this GOG version. Do I even need to mess with that file?
I've seen that you can do co-op in this game... is it worth it on a first playthrough?
SS2 is a game that is fundamentally about being ALONE. The sights and sounds of SS2 are all designed to instill in the player a dread sense of isolation and desperation. Be aware that by playing co-op, you directly undermine that authorial intent. The only reason SS2 even has a multiplayer mode is because the publisher demanded it.
I looked at some YouTube videos and I think I also prefer the SHTUP mod over Rebirth...I think I'll use that exclusively
Only if you want to.
There's a few GUI things you can edit, change the scaling of the menu's and such, but other than that, the 2.4 patch is what brought the game into the modern world.
Moding, at this point, is only needed to enhance the graphics. Pretty much all bugs have been squashed. That said, I'm on 2.4 and I still load bug fixing mods. That's more of a preference of minor things they changed, it doesn't conflict and works just fine with the new version.
If you are interested in what was fixed/upgraded (an incredible programming feat I must add) from the final official patch 2.23(?), look here:
http://www.ttlg.com/forums/showthread.php?t=140085
I highly recommend playing without Rebirth, but WITH SHTUP and some of the other more environmental graphic mods.
Is the GoG version 'mod ready' as described on the modding forums?
Yes it is, you can stick the mod manager inside and merge all your mods right after installing it. The Strangebedfellows forums suggest running SS2Tool after installing, but I didn't bother because everything appeared to be updated properly out of the box.
Try loading them in different order, it may work.
I know ADaoB 2.8 works with Rebirth 2, but I have not tried 3.0 yet.
Where can i find ADaoB 2.8? I want the Tacticool pistol that's compatible.
Also, is load order determined by the order you turn them on?
Here's my list so far, haven't ventured to turn anything on yet because my list is so big... i don't know where to start lol
They waited until I had grey hairs to do this!
WARNING : Playing this game will give you a deep hatred for the bioshock series.
Thanks for confirming this. I wasn't sure if it would cause problems, so i did not proceed.When the mod manager says some things are "incompatible" it just means that both mods try to replace the same files. In the case of ADaoB and SHTUP, I believe they both change the textures for computer monitors to be high res. In other words just hit "override" when the mod manager throws you a warning.
The order in which you turn them on DOES matter, but in the case of those two mods it probably isn't noticable either way.
Load Rebirth 02, first.
Then ADaoB.
2.8 has no conflicts, I still have not tried 3.0 yet though. Unfortunately, I was unable to find a link for any older versions...
If someone can host it, I may be able to help after I'm done with work today.
If you can PM me a link for upload, that would be best.
I don't want to sign up for any service for a single upload.
·PitBuLL·;1039665006 said:Never played SS2, but I just downloaded it from GOG to have it be my Saturday *bring my laptop to work* game.
Is there much of a learning curve to this game? Or can you just jump right in paying it a half-mind?
