I'm just not sure if the Coolermaster 1200 PSU will be able to handle all four cards and as the chassis needs to be starting it journey to CeBit this weekend i simply won't have time to test so not sure what to do for the best.
I think the best thing to do is install them all and sort it out when it gets back home as it won’t be running anything on the booth, just sitting there looking pretty.
Yes, but can it run crysis?
I managed to get some final pictures before it went into the box so this is the last you'll see of it, i promise.......even i'm getting bored hahahaha
Again, thanks for all the views and comments
<snip>
no doubt. that'd be a serious points producer.nice and with that power you should be folding
Why are you quoting a ton of pics? Is this your first day on the internet?Awesome, maybe some benchmarks before you let the thread die ?
Great work! I especially like the routing of the tubes from the rad house to the main case. Usually, when you see someone liquid cool every component in the system, the result is an overwhelming mass of tubing. This is a definite exception. There's a ton of tubing but it looks clean and pro! Two thumbs up, sir.
This has to be one of the CLEANEST builds I have ever seen!!
Nice job man!
