may i be worthy
[H]ard|DCer of the Month - December 2010
- Aug 17, 2010
hmmm - Chilly - you missing 2GB of ram?
Great job jamming it into the cosmos 1000. I have the same case that house a x8dah+f but plan on ordering the sr2 soon. How many of the stand off holes lined up for you?
may i be worthy said:Heads up - hacked bios that unlocks uncore.
I have put it on my x5650, and it works, currently testing just what it buys me.
Proceed at own risk.![]()
So...what exactly will/could this help with? After setting up my 980X with a 1.5x uncore I was surprised when the requirement for my L5640's was 2.0x. Will a lower uncore be a good thing? Will it even work?
Basically with the current bios uncore is locked at 20x. Loosening this to 19x or 18x reduces the vtt needed to be stable - but also loses a fraction of performance.
I have flashed my x5650 rig and have been experimenting - it does seem to allow slightly higher clocks, but it will take time to evaluate the benefits. So far it is not the second coming...
For me it is a subtle difference - I would be very motivated to start over if I was running 1.4v or higher vtt - as it is I am at 1.35 and 1.375 or each rig, so I wasn't being held back too much.
Still, it is a new thing to learn. But now I have another variable to test for![]()
I look forward to your results! I've been reading over the entire thread since I'm looking for every bit of advice, but it's a little tricky when many of us are using slightly different processors and the BIOS seems to have come a long way in only a couple of months.
I was able to clock my L5640's at 3.6GHz (9-9-9-24-1T 1600MHz) after about half of a day of stress testing, but I haven't made any effort to fine-tune anything, or see what I can get past 200 BCLK (if anything).
Now that I'm watching the points from -bigadv projects roll in I'm curious what kind of performance I'm still leaving on the table (from either CPU or RAM MHz).
So far I've seen average -bigadv TPFs of:
2684: 18:57
2685: 14:14
2686: 13:29
So many settings to tweak...
Have you turned off NUMA? You are about 1 minute/frame too high across the board compared to mine at 3.6.
I look forward to your results! I've been reading over the entire thread since I'm looking for every bit of advice, but it's a little tricky when many of us are using slightly different processors and the BIOS seems to have come a long way in only a couple of months. {SNIP}
There was a comment somewhere in the EVGA forum regarding uncore. I vaguely recall what it said was that the minimum was 2x for Nehalem and 1.5x for Westmere.
I am trying 19x, 18x, 17x etc and benching them on my captured 2686 unit.. more to follow in a full writeup later. The performance loss on folding looks miniscule...
14x uncore on my 2:10 x5660 does boot and show the expected amount of memory - for what that is worth.
I believe that's true, but for the life of me I can't remember where else I read it.
I had hoped that all my research would be of greater benefit to [H], but then you all had to find that goldmine of special cpus!
look 2 post up![]()
I for one appreciate all the work you're doing with the X56x0 chips. My X5650s should be back up and running soon, and I'd really like to be able to hit 4GHz.
Well, installing my board in a case seems to have cooked the OC on the L5640s. I think it's a temp issue, even with the open case. (I saw temps go a few degrees higher just by installing the SR-2 on the Mountain Mods tray but otherwise naked.) I've dropped back to my old standby voltages of 1.3V core, 1.35V VTT/IOH and I'm trying BCLK at 185 (= 3.33GHz). I've made it through a few LinX passes so far and temps are down more than 10 degrees. A few more LinX passes and I'll go back to F@H, and experiment some more later. I lost a few WUs already tonight, so I want to get a few successes.
It seems those L5640s are temperature sensitive moreso than x56xx chips. But I have had the same issue with my box. Since closing the PC-P80, I had to fiddle with volts as CPU0 (primary) shot up by something like 4 to 5 degrees at the socket.
Hey guys, hopefully I'll be getting a SR-2 soon and a pair of Xeons and start folding. Just a question, where do you guys get your processors? Ebay?
Just trying to cut down my costs as much as possible![]()
It's always nice to know I'm not the only person dealing with something. The L5640s definitely run cooler than my X5650s at the same voltages (and higher BCLK but lower clock speeds). I can probably get back to 3.6GHz with some adjustments. As it is, I only lost about 10K PPD on bigadv judging by the P2685 I got this morning.
eBay is the best place to find Xeon deals. I think all the L5640 "extra special" chips here came from eBay, but that well has run dry. I got my X5650s from TigerDirect when Bing was offering 15% cash back.
BTW, I went with G.SKILL Ripjaws for my new SR-2 build, and the fins don't seem to interfere with the TRUE heatsinks. The fins don't seem that much shorter than the Corsair Dominator, but I guess it was just enough. I'll know for sure when I actually mount the heatsinks.
I have ripjaws too and their heatspreaders are a little bit lower than most other rams (unlike Sector 7 or Pi or GEIL). I can fit them just under a thermalright silver arrow, but the 140mm fan won't fit. This is the difference b/t noctua nh-d14 and the silver arrow in terms of fitting, noctua's a bit better b/c it uses a 120mm fan on the outside.
Oh btw, what cases are you guys using for the SR-2?
Most people here fold nekkid.
I have a Mountain Mods U2-UFO and a Lian Li PC-V2120. I like them both, but the Lian Li is definitely more case for the money. However, the MM can fit on top of my desk without looking like the monolith from 2001.
