Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Dont they make some kind of extension cord that you would be able to route to the front?
Apparently the switch is in the connector on the back of the board, so if you were to plug in an extension, the speakers would go silent regardless of whether te headphones are plugged in on the other end or not
You can plug the case connector for the front of the case, but that plug only supported low impedance headphones (33 ohm if I recall)
