Gideon
- Apr 13, 2006
I don't think it's as simple as that. There are many stress tests that heat up the CPU more that run fine on any Ryzen. Also temps tend to plateau pretty quickly, long before the errors start happening. My 1800X hits about 64C on the die when running Prime95 Small FFT or the AIDA64 stress test, which is nowhere near the marginal limits of the CPU. It seems only very specific tasks trigger this issue.
You are correct it's not supposed to have a issue at 64c is also has no issue with prime95. Simple fact is this error is caused by a constant high load which is going to raise the temps which is then causing the issue when the bandwidth is nearing it's max and a signal degrades and it creates a error. Epyc and Threadripper are not affected due to the fact they use a different connection since there are multiple dies not just a ccx, would be my assumption. Either way it's not a huge deal and people that have the issue will get a fix, very few people are going to use the computer the way this fault happens.
