Final_Omen
- Jul 1, 2007
Let's start with my specs... (This is my first post too!)
Intel C2D E6300 @ 7x450
Asus P5B-Plus
Corsair XMS2 5400C4 2x1024MB @ 900 5-5-5-15
eVGA 8800GTS 320MB SC @ 600/1800
Creative X-Fi XtremeMusic (discontinued)
OCZ GameXStream 600watt
*Lian-Li PC-A12 + *2x Scythe S-Flex SFF21F
*Thermalright SI-128 + *Silverstone FM121
3x WD 2500KS 250GB
*2x WD 5000AAKS 500GB
*LG 18X SATA DVD Burner
*Anything with an asterisk I haven't bought yet.
My main concern is cooling. With the Lian-Li PC-A12 only has 2 120mm fans, will the 2 Scythe S-Flex fans be enough to keep everything cool... enough? Also, I am in the market for a down-facing HSF for my CPU to help cool my memory and northbridge. As of right now (Centurion 5 with side open, stock cooling + AS5, passive memory, passive northbridge) my CPU temp hits 82 in TAT. My northbridge I'm assuming is somewhere around 50-55, and my memory just slightly below that. My videocard also hits 77-78 full load @ 90% fan speed. So I know the new cooling setup will help alot, but is there anything else that I might want to consider, maybe different fans? I'm not to sure I could go after another case, after I saw the PC-A12, I was blown away. What an elegant, quality case. Also, will the down-facing HSF help cool my northbridge and memory somewhat? I'm definitely not expecting a 10 degree drop just from the extra air movement from the cpu fan. Any other comments or suggestions on cooling will be greatly appreciated!
Now in terms of hardware, is there anything I should of done differently? Even though I already bought the components, would you guys recommend something else in exchange what I currently have? Personally I'm very happy with the speed and overall price this system cost me, I'm very satisfied, especially with the overclocking results.
Speaking of overclocking, what should my voltages be at? I was thinking my temps might be too high due to too much voltage. Now I haven't gone into the bios and tweaked around until I found the right voltage for my overclock, and I wont until I get my new cooling, but just to help me out with that, can I get an idea of what my voltages should be at.
Finally, my soundcard. While the X-Fi is a decent soundcard, I think I'm going to see how the Auzentech X-Fi 7.1 Prelude does. Mainly because of the extra outputs ON THE CARD!!! However, it looks like it will be using Creative drivers, so thats a bit of a turn-off. Main reason I want to replace my current soundcard (even if the one I want uses the same APU) is because I hear crackling and pops once every couple hours, almost as if extra energy builds up and discharges at a certain point. Although I could be way off...
Anyways, thanks for any comments/suggestions/answers you guys can give me!
Asus P5B-Plus
3x WD 2500KS 250GB
