Across architectures ? It's the SAME architecture, which is why 800 SPs doesn't seem reasonable. There is no confirmation yet, but I would like to see those "official slides". You mean the suspicious looking slides, with extreme compression artifacts around the 800 number ?
Good God, Silus. You are wrong. It's 800SP. Please put down the keyboard and step away before you hurt yourself.
pcper said:The GPU-Z utility has been updated with support for RV770 cards:
You can see how fast our HD 4850 is running: 625 MHz core clock and 993 MHz memory clocks. Notice the 800 unified shaders, GDDR3 memory, 256-bit memory bus width and a die size about half that of NVIDIA GT200 chip.
AMD Radeon HD 4850 512MB Preview - RV770 Discovered
Legion Hardware said:Despite being the third fastest graphics card that has been named in the Radeon HD 4000 series, the Radeon HD 4850 specifications are still extremely impressive. The Radeon HD 4850 features a staggering 800 (160x5) SPUs, while there are 40 TAUs and 16 ROPs. Compare this to the 320 (64x5) SPUs, 16 TAUs and 16 ROPs of the Radeon HD 3870, and you quickly begin to understand just how impressive this new graphics card really is. The Radeon HD 4850 has a memory bandwidth of 64GB/s, while the Radeon HD 3870 was limited to 57.6GB/s of bandwidth.
http://legionhardware.com/document.php?id=755
ATI Radeon HD 4870 ATI Radeon HD 4850 ATI Radeon HD 3870
Manufacturing Process 55nm 55nm 55nm
Stream Processors 800 800 320
Texture Units 40 40 16
Render Back-Ends 16 16 16
Core Clock Speed 750Mhz 625Mhz 775MHz
Memory Data Rate 3.6 Gbps GDDR5 2.0 Gbps GDDR3 2.25 Gbps GDDR4
Math Processing Rate (multiply-add) 1.2 TeraFLOPS 1.0 TeraFLOPS .497 TeraFLOPS
DirectX Support 10.1 10.1 10.1
AMD Zone: ATI Radeon HD 4850
You can just say "Ok then.", or "Fine. I was wrong", or "Wow! ATi really did some great things with this chip!".
