d3athf1sh
- Dec 16, 2015
gordon mah ung at the frore airjet booth where they are showing off their solid state cooling (chips?)
Thermalelectric paint, it is way different than this tech.Complete side topic: What ever happened to that experimental "paint" or thermal-spray that generated electrical current from heat......I think this was shortly before Covid that maybe we were even discussing it here.......like you could paint an engine block, and as the block warmed it produced a current as a byproduct that could be tapped and utilized......is this an apples to donuts comparison to the product mentioned above...?
I'm sure, I skimmed the video but didn't see anything about durability for the membrane or anything. It's hard to beat the simplicity and durability of ball bearing fans, but the tech is neat!Looks amazing. Could be revolutionary, especially for notebooks. Can these "vibrating membranes" that move the air fail?
From their drawings it looks like there is always a gap in the channel, and the purported back pressure would add resiliency. Compressed air like on blowers and laptops would likely be fine too if that membrane can handle the pressure...Very cool tech. I wonder if it's able to handle dusty environments though. Is the inside able to be cleaned? Seems like such a thin channel would be very easy to clog.
Really? First response is of topic? WTF? Start your own topic.Complete side topic: What ever happened to that experimental "paint" or thermal-spray that generated electrical current from heat......I think this was shortly before Covid that maybe we were even discussing it here.......like you could paint an engine block, and as the block warmed it produced a current as a byproduct that could be tapped and utilized......is this an apples to donuts comparison to the product mentioned above...?
Not sure I am buying it. Very confused as to WHY they didn't retro fit it to a laptop by manufacturer X, and illustrate the difference between solid state creation and OEMs fan/pipe solution.
Don't get me wrong, it would be pretty cool if it works as advertised, but if they are showing it at CES and comparing to traditional in marketing, SHOW it competing with traditional.
EDIT: went to their website and they have some pretty light white papers/case studies, which is better. Would like to see independent testing.
Side note, in their "consumer comparison" video, I recognized the tatted up white guy as a childhood friend of mine. Crazy.
