- May 27, 2007
I've posted this in the other thread but want to share here also.
OK here are my results now that I've tested both Skyrim Acceleration Layer (SKSE) and Sky Boost R3
Sky Boost = HOLY @#)$#*@!
I have a 2500k OCed to 4.4ghz. I found a heavily CPU bound area, which was as soon as you enter the Whiterun front gates and are staring at the building that's just to the left (which is across from your home). I disabled VSYNC both in INI and in the CP. I'm using a blend of Ultra settings with ugrids @ 7 and some shadow tweaks.
With no acceleration I was at 40 FPS
With SKSE AL I was at 40 FPS. (other area's though i've found this gives me a 5-6 FPS boost *VERIFIED*)
With Sky Boost R3 - 60 FPS. That's a 20 FPS gain. Whiterun was absolutely buttery smooth as I could possible want!
I also went to Riften and Markarth and the FPS was butter @ 60 FPS. I'm absolutely floored at how much more smooth this game is now.
I absolutely recommend Skyboost R3 over the SKSE Acceleration Layer mod. Plus with Sky Boost you don't need to run a separate executable.
This is good news indeed! Thanks for the feedback. I also suffer from less than stellar performance in White Run and other random locations so I will have to give this a try.
