For those reading this article that either are not in corporate IT, or do not have to deal with per-core licensing, the AMD EPYC 7601 is a beastly CPU. Frankly, when buying your next generation of servers you should look into getting a few to run your workloads.
If you live in environments with Microsoft, Oracle, or other applications where licensing is on a per-core basis then your TCO calculations will look considerably different.
If your environment costs thousands of dollars per core, Intel is very interesting. If you are using open source software, or if you license software on a per node basis, AMD EPYC is going to be strong in many use cases. Performance even on legacy workloads is going to be extremely strong.
You could have posted the link to review... https://www.servethehome.com/dual-amd-epyc-7601-processor-performance-and-review-part-1/
And please, your bias is showing a lot. Posting charts of only perf / per core in a multi-socket & core environments![]()
C-ray:
1) Contains huge number of totally unnecessary sqrt and div calculations.
1a) These could be precalculated outside the loop.
1b) These could be (pre)calculated by much faster newton-rhapsody method.
2) Calculates everything, even pixel color values, with 64-bit doubles
3) Does not use any SIMD.
AFAIK, whetstone does test more than scalar div and sqrt. c-ray practically does not.
My beloved C-ray... I don't even care about that program but I posted it because it had the biggest win for AMDThere is also other reasons why I posted a Whestone graph instead your beloved C-ray: "Whetstone is much better than c-ray"
My beloved C-ray... I don't even care about that program but I posted it because it had the biggest win for AMD![]()
And you could have posted those total throughput graphs as well. There's a reason why I quoted those lines from article. Perf. per Core is important but there are lots of other factors as well which needs to be accounted when choosing the hardware.
I would like to contribute to this thread.
November mebbie ?
Only about half of the skylake-SP series is actually out right now.
I'm told the 6144's I want are October-ish.
That's probably why you can't find em anywhere.
The only xeon gold processors I can get right now are the 6154,6152,6150,6148,6142 and 6140.That's less than half of the complete line.
My supplier said he got a few more SKU's yesterday, but the 6144 wasn't one of em.
S'ok...I can wait.
