- Aug 24, 2006
I am building a rig in which I can play games like Crysis, BFBC2 at medium / high settings @ 25 X 16 resolution. After reading all the horror stories of dual GPU setup, I won't consider 5970.
So this is the ideal setup I wouild like to consider
1) CPU: Core i5 2500K/ i7 2600K
2) GPU: Superclocked 6950/6970/ or Superclocked GTX 570??
Now I've read that 580 @ stock speed is the fastest single GPU solution as of now (although this might change once ATI releases Catalyst 10.12). But the biggest problem with 580 is the Power consumption and Heat.
The power consumption is slightly less than 480 and because of better cooling system, nVidia is able to control maximum temprature at load. But overall it is a tough candidate to Overclock because of PCI Expression limitation.Although I am still open for 580
Now taking these cards into consideration ATI HD (6950/6970) / GTX 570, their power consumption and heat level is considerably low compared to 580. Thus making them potential candiate to Overclock. In fact a superclocked version with a good aftermark coolar might make these cards perform better than 580.
So what is your general suggetsion about this setup? and in future I can even SLI or Xfire. So which card should I go for?
