You talking about the kama bay coolers?
It looks just like a Kama bay, but the holes go all the way to the edges, and I think it just looks a little nicer. It looks more in the TJ09's league.
Yes, it is nice. It's definitely BIG, but I guess that's a good thing since there's room to grow into it.
This is off-topic, but I figured I'd share this since it might happen to somebody else. I had the weirdest thing happen when I moved everything into this case. NONE of my DVI outputs were working at all, so I had NO VIDEO. This of course put me into a panic initially, as I thought maybe I shorted out one of the cards or something. So I went digging and found the analog VGA cable that came with my Viewsonic LCD. I hooked it up with a DVI-VGA adaptor that came with the video cards. Sure enough video is working fine. So why the dead DVI? For the hell of it, when I got into windows I pulled the cards out of SLI mode, then turned it back on. Sure enough the DVI started working again. It's like either the cards or monitor itself got confused during the re-install. This ever happen to anybody?
this didnt happen to me but i noticed when i reinstalled everything, all my BIOS settings went to default again without me changing the jumpers. this is weird because i just replaced the battery in the mobo a couple of months ago and i cant think of anythign that would reset it. u tried the same you did with the HDD's but i didnt like how they could still turn a bit since it was with only two screws.
the only problem i have right now is getting the GPU fan out. i know which screws to unscrew but as hard as i try, they wont unscrew. and im afraid to strip the screw. any suggestions? ive got a standard sized phillips screwdriver.
Silverstone TJ09 Case
Corsair 620hx Power Supply
Intel Q6600 Processor
Asus P5K Premium Motherboard
Corsair 6400C4 2x1GB RAM
EVGA 8800 Ultra Video Card
2x Seagate 500GB HHD
Pioneer 18X DVD Drive
D-Link 10/100 Router
Vista Ultimate 64bit
Klipsch Promedia 2.1 Speakers
Gateway 21" LCD (already had)
Yate Loon 120mm Fans
Silverstone Bay Converter
Silverstone 3 Port Fan Controller
Thermalright 120 Ultra CPU Heatsink with Scyth S-Flex Fan
Taking a page out of nvusgt's book I decided to paint the inside of my new tj09 flat black.
Of course, that is not black...thats the white primer. When their painted black and I put the thing back together, i'll post more pics.
Whilst taking the case apart I decided to get rid of the silverstone GPU fan and replace it with a yate loon. I have no idea how you guys with everything already in the case got that fan out. It wasn't a huge pain in the ass, but trying to do it with all the components in it just makes it even more difficult.
Going to run the intake fans up to the 3.5" drive fan controller as well as install the silverstone 5" bay converter. Will post pics along the way.
hey hey, nice goin on the paint job.....sorta looks familiar
I'll be getting my TJ09 in the next 10 hours or so. Can't Wait!![]()
Get the Silverstone TJ07!
Have you people try the Silverstone CFP51-B Black Aluminum 3X5.25IN to 4X3.5IN Bay Converter with 120MM Fan And Blue LED? The only problem is that it'll eat up 3 of your slots but you can have 4 hdd in it.
Mine is set to your top option:
2x 120mm fan on top for intake
1x 120mm fan in inside near front for intake
1x 120mm rear for exhaust
The fans are all Akasa Ambers which seem to do the job well enough. I've got a Scythe Infinity with a push/pull set up with two 120mm fans. I've got everything cable-wrapped and tucked as best as I can and, after due experimentation, this has been the optimum set up for me (so far!) YMMV of course but this configuration works best for me.
Well you had me fooled. A minute ago I repositioned my CC tubes, I put one as you did too on the side of the gpu fan. I must admit thats a pretty good place as it cast the light more evenly. So are these recent pics or have you completed more ?
