I've done it on mine but I mean it wasn't a very good quality job.What you need to do normally is cutting the common ground between the USB and audio ports, could be a wire or in the PCB on the front panel but someone who knows that stuff should show us how
I just built a SG07 rig with an Asrock H67M-ITX/HT. I too get slight distortions from the front Headphones jack. Did not try disconnecting the USB cable. I need those front ports as well. Lack of proper shielding could be the problem. What do you think?
I'm going for the same build, SG07 rig with an Asrock H67M-ITX/HT.
What SSD/HDD, memoy, GC, and optical drive did you use?
Any issues?
Anyone else try this build?
Thanks.
That's essentially what you have to do. use a knife or something similar to break the ground connection traces for the audio socket on the board and then solder a wire to the ground of the audio header socket.
All you need to do is separate the audio ground from the USB ground, and connect the audio ground to go through the header instead.
Asrock H67M-ITX/HT
Intel SB 2600K
AXP-140RT + Scythe Gentle Typhoon AP-15 (1,850rpm) 120mm
OCZ Gold 4GB X 2
Crucial C300 256GB SSD (system, software)
Intel X25-M Gen 2 160GB SSD (games)
Seagate Barracuda Green 2TB HDD (other files)
SONY slot loading DVD-RW
Gainward GTX580 3GB
Issues:
very annoying static noise from headphone port on the front panel, interferencing with USB
have to remove the side windows since my Gainward card is 2.5 slot wide
Overall I'm very satisfied with the build,
Very helpful, specially those coolers you have.
Did they fit well in the case and are they worth it?
Thanks again
Also lack of USB 3.0, it shouldn't happen for a chassis launched in 2010.
If you want a powerfull GPU in smallest form you can get, SG07 is the best option yet. Hoping the SG08 will right the wrongs.
Hi,
I've decided on the build and started ordering the components.
Sugo SG07 B
ASRock H67M-ITX
Core i5 2500K
Kingston HyperX 8GB (2x4GB) DDR3 1600MHz
SONY AD-7690H-1
CRUCIAL SSD m4 - 2,5" - SATA-600 - 128 GB
Seagate Barracuda Green 2t
Sapphire Radeon HD 6790 1GB (hope it fits in the case)
I'll be using it, for htpc (3D in a small future), work, and some gaming, including small lan-parties.
I agree with you with the lack of USB 3.0 ports.
I'll not be using headphones most of the time, maybe in the lan-parties.
I'll upgrade the fans latter if i don't like the noise level.
What do you think?
I would go for atleast 6850, since you go for a SSD money should not be a problem methinks.
And 8 gigs of ram, not really needed tbh.
Also, k version not needed if you don't wait for Z68 board.
Well...thing is, Zotac Z68 will be available mid july...and methinks it will go out of stock very fast. Board looks nice no doubt, but Zotac had some troubles with it's boards, so it's good to let some folks test the boards 1st.
By that time (august) I'm hoping that the SG08 will show it's face. Not to mention the fact that Asrock might release a Z68 ITX board (just hopes here).
Also if you don't like the SG05, how about the SG06? (it has a white version aswell).
But if you go for HTPC and non demanding games, I would go for something way smaller as a case.
I personally like the Thermaltake Element Q
It can fit a low profile discrete gpu and a standard ODD.
Their is a white SG06? Where? Who sells that?
@ Lutfij
4 ssd's + 1 hd is easy , you can stick 2 ssd's with some double coated tape under the bracket for the slim-line cdplayer (see my pictures in last post or the one below, you can see the sata cables going under the cdplayer)
Temps (cpu) are ok, around 35 idle and 50-55 load (gaming), cpucooler is very quiet btw, it doesnt even spin up fast (pwm-controlled)
Temps (gpu) are ok, around 40 idle and 80-90 load (gaming), best is a rearexhausting gpu-cooler to get the heat out the case, but the con is they always are noisy at load (i don't mind, i wear a headset during gaming).
Here is a (bad) picture from the cooler, but clearance is good between cpu-cooler heatpipes and backside of gpu, you still can put a finger down there.
Already seen your line-up, my thoughts in red
quote Lutfij:
"Here's the NEW lineup:
Case: Silverstone SG07 good choice, good quality imo, better looking than future SG08 or older SG06/05
CPU: core i3-2105 just go 2500K it's faster and quadcore, it has better market value second hand later on.
Ram: still open to suggestions not thinking of OCZ's as i heard they're moving out of the ram market, any will do, i prefer corsair memory, went with corsair 8gb (2x4gb) vengeance
Mobo: Zotac Z68 itx to expensive just get a H67 gigabyte or asus board, better quality and better market value second hand later on
Cooler: Scythe Samurai ZZ good cooler, good price and fits easy
GPU: Later down the road, 5770 or 6870 BE dont know what you need or expect
HDD: will note the recommendation - hold out until prices drop and instead get a large drive; 1~2TB WD or Samsung's" dont know, not my specialism
The money you save on the board (H67 vs Z68), you can buy a faster/better processor instead, they are fast enough at stock, iff later there are more Z68 boards available you can still swop the board and do some overclocking.
Or if in time no boards (Z68) come to the market, then just stick with the H67 board and put a faster processor on the board when Intel comes with some die-shrinked faster clocked cpu's to the market.
You did mention a good thing though about the Z68's...but will still want to wait for SSD's to drop in prices
i'm a real noob with SSD pricing I don't know how much to spend on one...?
But one that funstions ONLY as a boot drive and a some games(but mind you bro - games aren't my first priority)
What dya have in mind?
i used my fingers to twist the cables on one mod - though its now sold to a pal of mine...Standard sata-cables are way too long for this case, so i twisted em around a pencil to shorten em fast and simple.
- um FYI even if your not an OC'er, the cablemanagement helps lower temps and lengthening component life. I did cable management on my E4300 rig with an xfx 8600GT Fatal1ty passive DDR3 edition and i was able to play for longer hours on an Intel DG965RY board.That will be proper cable-management or else no cable-management for me
@ jwcalla - i wont look into 2nd hand SSD's too unreliable but you have any recommendations ?corsair, OCZ, mushkin's ?
That's one of them. Then there is the 310 and the 510.
Any major brand should be okay... though I'm beginning to feel a little queasy about OCZ.
Corsair just had a recall on their Force 3 product.
Thanks alot bro for the reply and feedback!
here's what I'm working with atm -
Rig 1 : (writing this message from)
Q9550 E0
Asus Rampage Extreme w/Supreme FX X-Fi
OCZ 4GB 1333Mhz DDR3 Platinum Edition
Corsair H50 modded w/ Fusion block system, dual rad w/ p/p
320GB WD Blue 16MB - OS Drive
2x500GB WD Caviar Green 32MB in Raid 0
500GB WD Blue 32MB
80GB Seagate Barracuda (pata)
Asus DRW-24B1ST DVD+/-RW
XFX Radeon 6870 Black Edition 1GB DDR5
Thermaltake Spedo
Thermaltake Toughpower Grand 750W
Creative I-trigue L3800
Samsung P2350
Microsoft Xbox360 Wireless Controller
Microsoft x6 + x8
Rig 2 :
i5-750
Asus Maximus III Formula w/Supreme FX X-Fi
OCZ 4GB 1600MHz DDR3 XMP Edition
Corsair H50 with p/shroud/p
320GB Samsung HD322GJ
500GB Samsung HD503HI
HP litescribe DVD+/-RW
XFX ATi HD5770 1GB DDR5
Thermaltake Armor Jr
Thermaltake 850W 80+ modular
Cambridge Soundworks FPS-1000
Samsung P2250
Microsoft Xbox360 wired controller
Razer Starcraft Marauder + Spectre
So now you know where the 5770/6870 BE comes from...? I was thinking of recycling it from my build(s) and get a single powerful card instead of crossfiring them. The SG07 build will be for a 24/7 torrent/seeding/HTPC rig and one that is gaming capable @ 1080p resolutions. "This" rig will be hooked to a LED tv...still deciding on what size to get from malaysia.
The pictures speak alot. Thanks - gave me ideas as well.
I think you could do a better job of the cables inside the case. Why don't you route the sata data cables round the sides of the case...and out of the way? like this forum poster
will do better for your temps IMO
How much space is between the bottom edge of the long GPU and the bottom of the case. Is there 10mm?
