fyi, since I don't think anybody has said it, i confirmed last night that a full ATX mobo does fit in this case just fine.
However, I don't have mine up and running since I don't have a spare mobo with integrated video, and I don't have any pci-e standoffs.
Yep. Go for it.It will hold a full size ATX board for sure? Wanted one know I have to get one. I have a msi 939 ATX board that needs a home.
Just out of curiosity but is there any particular reason you're ditching the included psu?Case was delivered last night. I'm gonna have to dremel the DVD/HDD tray slightly to make room for my heatsink and I'm still looking for a decent deal on a PCIe 1x riser ribbon cable.
I've decided to ditch the internal Enhance PSU that came with the unit and run an "external" ATX PSU in its place. Should still look classy, we'll see.
Hope to put together a build pictorial when all is said and done.
Pretty sure he arranged fans the standard way, it's not like there's much height to the case but normally you'd want thermal convection working in your favor. This doesn't take case layout nor air pressure into account so, for all i know, your idea may work better.I would reverse all those case fans if I were you.
Posted via [H] Mobile Device
Good ideas imho, and good point about the top case fan and Cpu fan competing for air.You're right and I didn't totally mean what i said.
What i really am concerned about is the heatsink fan and the fan above it blowing in opposite directions, fighting for air.
Reverse that one so it blows down on the cpu.
Also, make the fan on the left of the case an intake. On the right, exhaust.
That config solves all issues
Making more space? power hungry components? or both?
Would definitely like to see some pics, good luck either way though.
Will it fit a xp90c heatsink?
Ya, unless you get a good low profile heatsink then a quad-core CPU isn't the best fit for this case. Another problem is that it drives costs up further, but i guess HTPC enthusiasts are used to buying silent after-market parts so it's probably par for the course.My heatsink experience trying to keep an Athlon II X4 635 (2.9ghz) cool in this case:
Cliffs notes: buy the Scythe Shuriken.
