Quick thoughts:
Wow. No top vent. Sorry you drew the short straw. I would be in trouble with my quad.
The Scythe Shuriken will still fit in your case, and it would definitely help keep your CPU temps down. You could blow it down onto the CPU or up away from the CPU. Either way, if you run into CPU heat or HSF noise, that would be a good option.
That slot cooler doesn't intake air from what I can tell. It just blows air around.
You might want to consider Thermaltake's dual slot PCI fan. I assume with some undervolting it would be your best airflow/noise ratio. If you did get this, you might want both side fans blowing into the case then the PSU fan and PCI fan would be exhausting.
Maybe it would be worthwhile to contact the seller if/when you buy another one to see about buying a lid with vents?
Regarding the size, yeah. It's basically exactly as big as an ATX mobo with a little room for a PSU.
