jeremyshaw
- Aug 26, 2009
I'm tempted to dremel if the holes of the Max 4 GENE don't line up..... I had this issue with the P8P67-M Pro, too, and I am unwilling to put up with it again.
On the cable holes it's not the first time Silverstone messed up. The TJ07 is a pain too, the cutouts in the bottom section don't line up properly for the power supply and the hard disk mounts.
prava
I totally agree with you on SATA cable holes. At least your SATA ports are facing down toward the bottom of the case (which mobo is that btw? I see it's an ASUS. Mine is H67M-Pro). Mine are facing toward the side panel, plus 6 ports are oriented in such a way that if I used 90-degree angle latch, it would interfere with other ports right next to it.
prava, you arent kidding about the mess of cables. lol.
i mounted my ssd facing out, and ran the cables underneath/behind it. much cleaner that way.
https://www.facebook.com/photo.php?pid=18141508&l=48097e9c88&id=697965296
How is temperature on your WD Black after playing for a while? And gpu temps?
I ask because your VGA exhaust directly outside the case and I wanna see the effect of that (my HDD on idle sits at 30ºC and when I'm gaming full load peaks at 41-42ºC. I may have to change the VGA if doing so will improve overall temps.
mine is actually a lot warmer that that. 41 idle, about 46-47 on load. i dont have it in the hot swap bay where the side panel with that block will passively cool. I wonder if that is making the big difference. the vga in mine exhauses right out the top, but the two stock ref 6870's still like to burn up on their own. they idle at 48, and peak as high as 91 when killing it. i notice when dropping out of a game, they will drop rapidly, and visably so i know the fans are doing their jobs.
Going to attempt my first build with the following components (ordered today):
Case Silverstone FT03
Fans 3 x CoolerMaster 120mm & 2 x Zalman 80mm
Processor Intel Core i7 2600K 3.40GHz
Cooling Corsair H70
Motherboard ASUS P8P67-M PRO
Memory CORSAIR DDR3 1600MHz 8GB 2x240 DIMM
HD 1 250GB Intel SSD 510 Elmcrest series
HD 2 1TB Western Digital Caviar (7200 RPM) (64MB Cache)
Optical Sony Optiarc Blu-ray SATA BC-5600S
PSU SilverStone STRIDER PLUS GOLD 1200W
Cables 1 SilverStone (SST-PP05) Short Cable Set for Silverstone Strider
Cables 2 3 x 15cm SATA cables
Adaptor SlimlineS-ATA cable
Can anyone see anything missing (aside from the GPU)?
I am going to be running a 30" monitor at 1600p, what GPU should I be looking at?
Trying to decide between: 2x6990, 2x590, 2x6970 or 2x580.
Also, what's the best 30" monitor out there (for gaming)?
Finally any advice to a first time builder would be very much appreciated...
Cheers,
Tom
I think I'll go with the Dell U3011 with GeForce 590 Sli
Indeed, it is still somewhat of a prototype at the moment, so hopefully they'll fix all of the shortcomings.Yeah, wait until the newly polished GTX 590s come out in a month or so!
The case should come with everything that you need. Make use of YouTube to check out other builds with this case. Going by reviews on NewEgg, this case doesn't seem to be the best, though. I sense a revision coming for it soon.
I also commented on your similar bit-tech forum post, but would like to hear feedback on my comments from the people in here.
2xGTX 590 with no spacing in between. How is a center placed fan ever gonna breathe on the first card. And if it is this design How are the front GPU going to breathe. I don't have experience with dual card configs, but can't see anything working other than 2xcards with fan designs similar to the gtx 580 reference.
My suggestion in there was either 2xGTX 580 or 1xGTX 590. Both make compromises, with GTX590, the CPU is gonna run hotter, with 2xGTX580 I believe the first GPU would run hotter than the second.
maybe the 80/92mm bracket with a nice, fast fan on there blowing in towards the center fans on the GTX590s
And reverse the 120mm fan on the bottom.
As for the PSU, only option is the HCP 1200, which fits (I have pics somewhere, if you want).
Everything has been ordered now and, as I live in Japan, will be hard to return... so I will try and make 2x590 work if at all possible. According to some benchmarks I saw 2x580 can't cope with 1600p at max settings (inc. AA). Lt alone 3x1600p which I want to go too eventually.
I got the Zotec cards btw
http://www.techradar.com/reviews/pc...ds/zotac-nvidia-geforce-gtx-590-937805/review
Thanks for all your help - I'll post pictures of the build when I get started
But the HCP1200 appears to be larger than the Silverstone Strider 1200w (which I have ordered)
I have just ordered a 92mm 2000 rpm fan for the top as you suggest
So I have 2x80mm pushing air out at the bottom and the top fans sucking it in? I thought it was meant to be the other way round?
The HCP1200 fits. My own pics
Uploaded with ImageShack.us
Reason why I had a HCP 1200 was I wanted GTX590 SLI at one point, lol.... anyhow, it was the only PSU listed on nVidia's official compat. list, and given [H] and Jonnyguru's slight nudge for this PSU (barely the best PSU ever reviewed by either, but the best nevertheless), I eventually went with it as it was the most powerful PSU capable of being fit into this case
Silverstone's recommended PSU limit is 180mm for modular PSUs, and I agree with SilverStone's assessment.
The Sparkle 1250w is another option @ 175mm long.
Normally, yeah, but the GTX 590 (like the HD6990) blows air out of both ends so if you've got the bottom fans blowing up they'll be running into the air coming out the front of the video cards, which is going to result in worse cooling and the fans working harder. Really, vertically oriented mobo cases like the FT03 and FT02/Raven work best with cards that exhaust entirely out the back; I wouldn't be too surprised if the GTX 590 performed worse, temp-wise, in this case vs. a standard case.
According to the manual the max for modular PSU is 160m, which worries me somewhat!
the manual states 160, 180, and 210 mm.
I'm just stating real world experience, which is infinitely more useful then that manual![]()
You want to forget about GTX590. You don't want any GPU that doesn't dump the heat outisde by itself, because you will wreck all other components temperatures.
I had a Gigabyte GTX480 SOC in my case (just one), and all my temperatures skyrocketed: HDD max temp peaked at 46ºC, and cpu temp was along 55ºC (gaming, no overclock). Now, I swapped it with a GTX295 (that at least dumps part of the heat outside) and the peak HDD temperature has been 40ºC and cpu temp was 47ºC (same game).
Now, If you keep in mind that the GTX590 only dumps half its heat out the case, then its a no-no because you only have one exhaust fan. 2 x GTX580 should work, imo, at least if they are reference cooled cards.
If you go 590 route you wanna keep the side open and have the bottom intake fans as exhaust, as the GTX590 dump heat from both sides.
Otherwise you are going to fry your componentes no matter what kind of fans you put there, I'm telling you.
I found someone else who has the same setup!
http://forums.hardwarezone.com.sg/showthread.php?t=3167296
I was going to order a lian-li v354 before seeing this case, now I'm definitely going to buy this one!
I just have some doubts, what do you say?
1) H60 or Antec KÜHLER H2O 920?
2) 2x6950 or 1x6990?
