Sick of Creative
Met-AL said:
I'm sure you should know, but....
THat's skewed, and always has been, the thing is the APU is ONLY used when encoding 5.1 in realtime over the digital out. Otherwise it's using the board's AC97 codec chip, at which point it IS no better than other onboards since it's using the same exact hardware as other onboards.
Basically Tom was comparing apples to oranges since those other cards in the comparision couldn't do dolby digital encoding in realtime.
by the way, my board uses the cmedia8738 for it's ac97.
The codec is only used for it's DAC's. That's it.
And you would never "encode" while playing a game anyways.
LINK
In the nForce2, NVIDIA shows how a chipset can hold many audio features. This is the most complete of all to date. The audio section is managed by an APU (Audio Processing Unit), which deals with all the main audio functions (MIDI, Wavetable and 3D restitution). The APU can also encode in Dolby Digital format in real time, though this is not yet relevant for games. The chip is compatible with Direct Sound 3D and EAX 1 and 2. Like a sound card, it processes sound without putting much of a load on the CPU.
This shoots your theory that he was encoding something while playing a game.
The results are not skewed. When I benchmark Q3 with and without the sound, I get similar results percentage wise.
Also, this all depends on the which version of the MCP you have on your NF2.
If you want to go thru the hassle of using your NF2 APU with your SB's DACs, check this thread out:
http://www.nforcershq.com/forum/viewtopic.php?t=58829
MartinX said:
For game audio, Creative is the best, this is not disputable.
For music listening, they are inferior to other products, but not at all times under all circumstances and never by much, if you pre-resample using foobar/winamp you've already wiped out most of the Audigies problem (for free!).
Basic rule of thumb: if your headphones cost more than the card, you may want to consider something better.
Basic rule of thumb2: if your Amp cost more than the card you really should consider something better.
On drivers, I never got this one, I just use the custom install option to put in the windows drivers and the Audio console and nothing else. How is that hard?
That said, I'm constantly suprised at how few people know that there is a single no-frills tabbed interface for controlling everything important so you don't need those stupid cartoon individual apps for everything.
On clipping, I never put the volume in windows over 50%, I mean that's what amps are for, surely?
I'm just saying that the control apps are total bloatware, and that the drivers are quite buggy. I've had numberous times where my sound just quits working, no reason, just stops, so I have to go and restart my machine to get it working again. Very annoying. It's a shame that Creative is the only option if you want to play games with very good sound, althought it seems that more and more games are migrating to using their own sound engines instead of EAX, which looks hopeful.
yeah, ever since creative totally fucked the drivers/support for the external drive on my audigy platinum which i paid something like $250 for 2-3 years ago SPECIFICALLY to use the external drive i've vowed to never ever buy creative again. lousy bastards
My audigy 2 or any of my audigy 1's have never given me or my klipsch/logitechs any problems. I have been on every chipset, different processors. No probs at all.....Go creative....
actually now that the HDA mystique is out, i would hold off on creative and consider the HDA instead.
i ordered one to replace my audiugy 2 zs because it can be frustrating....... sometimes i've had probelms with the setting changing for no good reason, or resetting after changing them. I also had the problem of the different channels of sound coming out of the wrong speakers (not an error on my part since it worked prior to me reinstalling the drivers), and the only thing that fixed that was a format. Also, the sound from the analog jacks from the audigy is thin.
Yeah that HDA Mystique looks awesome, i might have to consider it. Anyone know a good place to buy it from?
enelson125 said:
I'm just saying that the control apps are total bloatware, and that the drivers are quite buggy....
Yeah, I'm not a fan of the way the separate control guis works, which is why I don't use them.
I've never had any technical problems with Creatives drivers.
enelson: The kxdrivers are a great alternative, but they don't fully support the Audigy2 ZS yet, so you're out of luck there.
The Mystique (monster of a name!) looks great, and I'm praying it will be a creative-killer, but it hasn't been around more than a couple weeks. I wouldn't put my money there until there are more peer tests and experiences out, but thats me.
Check out the thread on it:
http://hardforum.com/showthread.php?t=899864&page=1&pp=20
But like everyone has said, if you want all of the gaming features, you're stuck with Creative. You COULD downgrade to a plain Audigy 2, which is supported by the (great!) kxdrivers, which I can say are good from personal experience.
The M-Audio Revo 5.1/7.1 are also an option, though I don't have experience with them, you could ask (anyone?) around the forums about how people who have them like them.
There is also Turtle Beach (Catalina 8) and Chaintech (Chaintech AV-710), though I think those are on a lower level as far as features and quality from the newer and more expensive cards we have been discussing here, but its nice to know what your options are.
Have you tried putting the Sound Card in another PCI slot? Sometimes that helps with IRQ sharing/conflicts etc. :)
I'm still running a Live over here... I also didn't install any bloatware drivers, just what I need from Creative. Never had a problem with sound. Perhaps it is IRQ conflicts or crappy AMD-motherboard chipset drivers that are causing problems?
I run a Audigy 1 with a digital I/O daughter card. I haven't had any trouble with it, but the sound card is the only thing I don't dare mess with the drivers. I went through a few different revisions of drivers right when I got it and found a set of perfectly working drivers. Ever since the original issues I have had no problems.
I want a PCI-Express sound card.
What device provides A/D conversion and S/PDIF IO if "that's it"? ;)
LINK
Pretty much shoots that comment down doesn't it? :p
How else do games like FarCry provide Dolby digital audio then?
http://www.farcry.ubi.com/system.php
NVIDIA® nForce™ or other motherboards/soundcards containing the Dolby® Digital Interactive Content Encoder required for Dolby Digital audio
Pretty much shot that comment down in flames as well. :p
steviep said:
Indeed it is incredibly hard to hear the artifacting that occurs during the 48-to-44khz conversion process. Other than the M-Audio, Creative has the best-sounding hardware, plus it is much better with games. Again, if you game, stick with it. If you're a music buff, go for an M-Audio. We have yet to really test the Mystique card yet.
Dude the chaintech AV-710 sounds better than the A2ZS not to mention the 6Fire :p
enelson125 said:
that alternative driver looks like something good to try. I absolutely hate creative's drivers with all the shit packaged with em. Theres also way too many different updates to install, that I feel like I missed something or its incomplete. Creative really needs to make a unified driver package or something that isn't so annoying.
I guess my complaint is more of a subjective complaint, but the sound doesn't seem at all immersive. Just kinda flat, in games too, even with their fancy EAX3/4.
My speakers aren't bad either, I have the Logitech Z-5300e set. And I have the standard Audigy 2 ZS. I also have a pair of Sennheiser HD-515 headphones.
true.. I just wiped my machine and reinstalled windows.. Had to DL like ~5+ creative drivers and reboot between each one... man, pain in the ass.
true.. i had huge problems with my 2 ZS, spoke to creative several times, my problems went away when i place the card in the bottom PCI slot (furthest away from AGP slot).
I do. In high sample mode, the Chaintech AV-710 sounds better than the A2ZS. Who cares about EAX when my music sounds better? Of course, my Revo beats them both. I also don't game much.
LINK
The NF2 APU does all the work in hardware and doesn't cause a huge framerate loss like using codecs do or M-Audio cards. The codec provides the DAC for the analog out and isn't offloading the sound processing onto the host CPU.
And I was refering to the benchmark that Tom's Hardware was running. There was no encoding going on in that to make it unfair over the other soundcards that don't support real time encoding if that would be unfair..
