catalystsupreme
- Apr 13, 2006
Does anyone know where I can find a shroud for the Swiftech MCR320-QP-K Triple 120mm. I prefer a triple
Viper87227 said:i did #3 mentioned above. Get some cheap fans and hollow them out. Works great, its cheap, its easy, and it looks the best.
Stealth Micro said:yeah ,thats what i would do also,both for looks and ease of install.@ just some longer screws~
I double checked the shroud at voyuermods, its actually just a flat plate design.it is for a triple alphacool rad but it may work for yours with a bit of hole hogging,not my first choice but you may gain a 1/2" with some 1/4" x 1/8" wide foam neoprene or weaterstrip tape.................peace
