Show Your LCD(s) setups!!!
elvn
yes other than plasma, a tv with good blacklevels and detail-in-blacks that is LCD is a VA type lcd, which is bad for gaming. TV's also have scalers which introduce additional input lag (though many monitors have scalers too if you don't purposefully avoid them). The perceived ppi at distance comes into play. A 27" 1080p or 2560x at "normal" desk viewing distances is preferable to me, or as part of a LLL eyefinity with the side panels for immersion. Any monitor much over 30" at a desk is eye-bending to the periphery too - which is different from LLL eyefinity where the side panels are mostly peripheral by design. I don't like those centric bars in PPP eyefinity at all, and the pic I posted shows good reasons to choose a differently in regard to games. Using a LCD TV is a poor choice and not even an option as far as I'm concerned. To each his own though. Its discussed in plenty of other threads.
suiken_2mieu
50:16 or 25:8 is what I'm running. Which is very close to those PLP setups. It's wider than a single screen. Also, this thing is so huge, it completely immerses me.
elvn
Yep, I never said 5x1 = same aspect as 1. PPP is close. I agree that 5 is closer to a PLP aspect and you can extrapolate both of those concepts from the bottom two aspect ratios on the picture I posted. Your personal eyeball FoV is partially related to your view distance to your monitor also, as is your percieved ppi/pixel size. I don't like having to bend my eyes up vertically and to the corners to see stuff in my periphery on my main game view space on monitors over 30" at desk distances, and I definitely don't like the more central bars especially when I can get similar central FoV on a different monitor. PLP is nice if eyefinity supported it and monitors were still made that support it better . 5x1 replicates it and at a higher ppi. LLL eyefinity may be overkill on the overall width compared to PLP aspect, but it works and has no central bars. On games that support it properly, your main gaming space is maintained and within scope of your normal gaze, with HUD, pointers/notifications, chat, etc all in that scope. PPI aside, I've had 37" monitors at my desk and the vertical is annoying imo. The only way I would use a huge wall-of-monitor is if you could assign a main virtual monitor size and have the view outside of it additional FoV , rather than just jumbo sizing the whole scene.
Between both 5x1 and LLL , ppi and the central bars are the tradeoffs of course (as well as things like price, AG coatings, scalers, etc depending on the monitor type). I just don't think its worth it personally, mainly because of the bars when I can have three 27" LLL 120hz (or even a single one relatively close) in front of me with no bars in my face/main gaze. You will find proponents of both of course.
suiken_2mieu
@elvn: I have to agree that it's quite large. On games in which you can manually dial horizontal and vertical FOV, you could do this, the only thing is that you would see more distortion (if that bothers you). I've always wanted to do this, especially for setups that have even number of monitors. Like a 2x2 or 3x2 where you could also move the viewport to a certain monitor and extend from there.
EDIT: SoftTH apparently allows you to do this now, but for SoftTH to work, you still need more than one desktop.
Goodfellah
Well I got my new 2007fp's in yesterday, I now have some serious appreciation for you guys with more than 1 dell 30" monitor, I have everything all setup with the 20/30/20 PLP setup and DAMN, it looks incredible, its also HUGE. Waiting on an adapter that should get over here so I can get the third monitor hooked up. Had no idea dell financial services would have these monitors at my house in 3 days, that was pretty amazing too. Pics soon!
lillimon04
Aww man I almost got a 30inch off craigslist and was going to do this same thing because it looks amazing but he freaking sold it from under me. :( Told me he was going to hold it too. :mad::rolleyes:
wagoo
Here's my 5x1P plus a couple extras setup. You really need a screen in landscape still for watching video, I find the bezels disappear when you're busy gaming though. I think this will do me until new 3840x2160 (3840x2400 wishful thinking?) screens start to appear..
Work mode:
Game mode:
From left to right, they are: Dell 2405FPW, U2412M, U2412M, U2412M, BenQ FP241W, NEC 2190UXp, Dell 2005FPW
Goodfellah
Quick shot, right after I got them hooked up. Will take more shots tomorrow after I have it setup the way I want and I clean up the cables!
2007fp / 3007wfp-hc / 2007fp
-G
Wibla
Finally swapped the last HP 2335 for a HP LP2475, 3x24" ftw.
Also removed a usb hub that had been annoying me for some time (cable mess), using the hub on the HP monitor + cable hiders behind it.
esmith2039
Nothing fancy HP DV5-1002NR with LG 32LK450... does ok no complaints even with 3D drawings in AutoCAD 2010. HPw2007 on the side is for work laptop.
Goodfellah
Goodfellah - wallpaper link? Are you using a program to split the 3 desktop wallpapers?
I am using the free version of Ultramon to get the task bar and wallpaper across the three screens, I was able to find the wallpaper by searching 4960x1600 through google images, your other option for wallpapers are the 7680x1600 and using those centered or compressed.
Either way, very pleased with Ultramon thus far, but the availability of wallpapers for this setup is severely lacking.
Willmaster
Updated.... :)
Antec Twelve Hundred
Asus P8Z68-V PRO/GEN3 Mobo
4x4Gb Corsair Ram (DDR3-1866)
Aplenföhn Brocken CPU cooler
Intel Xeon E3 1230 @ 3,8Ghz (Yes, you CAN actually OC the Xeons)
5x 2TB SATA2 HDDs (Mixed WD, Seagate and Hitachi)
2x Sapphire Radeon HD 6870 1Gb
2x Sapphire Displayport -> DVI (Single) adapter
6x Acer P236Hbd FullHD 23" Screens
Allcam mounting System for 6 screens
System with 6nd GPU just installed:
System running:
Openarena across all 6 screens:
Any comments? :)
wra18th
[H]ardness Supreme
Six screens are so sexy....omg, omg, omggggggggggggggggggggggggggggggggggggggggggggg................
Blazestorm
[H]ardness Supreme
Looks nice, although I think I'd prefer 5x1 Portrait over stacking them, easier to line up, and no crosshair hiding in your bezels.
N H O
http://dl.dropbox.com/u/8352385/EVE/DSC_4549_web.jpg[IMG]
Also removed a usb hub that had been annoying me for some time (cable mess), using the hub on the HP monitor + cable hiders behind it.[/QUOTE]
is that bias lighting i see? if so, mind posting a pic in the dark? thanks
t0asty
^^ my goal. Very clean, great job. Wish the gpu companies would support that set up and we could all live in perfect harmony.
Goodfellah
Very nice. What desk is that and where can I get one. I want a flat open desk like that as well.
* [ikea vika amon tabletop](http://www.ikea.com/us/en/catalog/products/80071164/)
* [(3) desk support legs](http://www.ikea.com/us/en/catalog/products/10105290/)
* [case holder / desk support](http://www.ikea.com/us/en/catalog/products/40162496/)
* [led's mounted to backside of desk, switch underneath](http://www.ikea.com/us/en/catalog/products/20119418/)
* [galant cable management tray, couldn't find my exact one it is much larger](http://www.ikea.com/us/en/catalog/products/20195596/)
Goodfellah
Yeah I agree 100%, when I put games in window mode the frames arent great, but wow it looks cool, still enjoy playing just off the 30" in the center too though.
davidm71
Are all three the same monitors or is the middle one different? I thought they all had to be the same size?
davidm71
Why not? GPU's have had multiple outputs for well over a decade now.
I thought nvidia clearly needed three monitors of the same type to expand the screen. I mean I'm sure you could have different size monitors but would not be able to game at triple monitor resolution. I could be wrong though. Some one please correct me if I am..
fenixv
Well, you can game across all three screens if you play in window mode and stretch it. You can't do it full screen yet though.
As far as his picture, it looks to me like his desktop.
Zorachus
[H]ardForum Junkie
Turned out nice.
Clean and just perfect. The Portrait + Landscape + Portrait looks so much nicer than my 3 Landscape. I scratch my head wondering why AMD still does not allow P+L+P in Eyefinity, after two plus years. The driver team two years later still can't figure out how to get a 20"+30"+20" to work in gaming ?
retro
Not nearly as clean as some others here, but I figured it was about time I put it up.
2x HP LP2475W's and 1x Dell 2407WFP. Hoping to replace the Dell as soon as I find another reasonably price HP on the used market.
