10+ for that post, the situation which I had 4GB of RAM and would show only 3.24GB it was because of my 512MB of VRAM, plus 128MB of AGP Aperture Size and the other devices.
Could someone calculate how much space address is using my card? Thanks!!
http://i238.photobucket.com/albums/ff157/evolucion8/Resources.jpg
I have a 9800 GX2 now, which is 512x512 (mirrored) so why do I only have 2.56GB of my 4GB available as system ram? when I had 2 8800 GTX's it was the same ammount, no change.
What else gets mapped other then videocard memory and system memory?
Your 3800 series card is reserving 256mb of addressing space.
By the way, google can do the calculations too.
http://www.google.com/search?hl=en&q=0xDFFFFFFF+-+0xD0000000+in+decimal&btnG=Search
Thanks!! I just need how to learn to find and interpret those values... But I will figure it out somehow...![]()
I have 4GB installed on a 32 Bit OS with an X2, I haven't had any problems Playing Supreme commander: Forged allainces, Farcry 2, Spore creature creator and two older games.
Any of you want a screen shot of something?
So was there a final word on this? Should I go buy an upgrade Vista Ultimate? XD
64-bit vs. 32-bit is what matters in terms of memory limit, not Home vs. Ultimate.
Yes please. Device Manager->Show Resources By Type. Expand the Memory section and take a screenshot of that pleaseIt should look similar to the screenshots evolucion8 and I posted.
Sorry for the confusion, I meant it saying, should I go out and buy that 64bit vista ultimate that I've been eyeing using the upgrade workaround hackThough might just go with Vista Home Premium. There's no seperate versions of Vista right? Not like the old school win xp 32bit and win xp 64bit?
That's correct. All Vista editions have a license that lets you install either 32 bit or 64 bit (but not both at once). You just have to have the correct media.
Retail versions are 32-bit only, except for Ultimate which also comes with a 64-bit install DVD. If you buy Home Premium and want to install 64-bit, you have to request it from Microsoft for like $15 and they'll give you the 64-bit CD-Key and install DVD.
I can't upload it, all sites Ive tried won't allow bitmap image uploads.
Someone throw a site that will host a Bitmap Image of about 7 MB
I can email it to someone if they wanna host it.
Edit: Ill be back in a few hours, so someone who wants the image should give me a site that will allow a 7 MB bitmap image upload, or give e thier email so I can host it.
Cause no sites that I have found have uploaded it..
Well, Like I said, I have had no problems with any of the games maxed out on My XP Install.
Farcry
Zero hour
Armada 2
Supreme commander: forged allainces.
granted they aren't real ram suckers, but no problems...
You've got two 256MB regions and two 64k regions mapped to your video card, not counting the A0000-BFFFF "compatibility" region. So a tad over 512MB.
@Blueeagle: How much usable RAM do you have? About 3.2gb? (I think you'll have to check the task manager for total ram - not 100% positive on that, though)
I have bad news for P5W DH owners:
i was running an 8800GT 512mb and had 3,16 Gb with memory remapping enabled and 3,25Gb with memory remapping disabled on XP 32bits SP3. after i installed the 4870X2 (Saphire) my memory went down to 2GB with memory remapping enabled and 2,6GB with memory remmaping disabled.
I have a huge B0000000-BFFFFFFF adresse for the the 4870X2 that does NOT shows on the other screenshots here, plus i have been unable to install the audio device driver of the 4870X2 on XP SP3.
Any hints?
Upgrade to a 64-bit OS. Its really you're only choice (or sell the card and get something else, like a 4870). Nothing is actually *wrong* with the system to fix, its just how it works.
