pics of wife?belmicah said:Beautiful. Small explosive package. Like my ex wife. BOOM!!
rawr, i bought a refurbished warrantied as new case from frys and it didnt have any screws in itkezmo said:Screws :s erm iirc they came with the sugo not 100% sure tbh![]()
kezmo said:Temps seem low
Speedfan Readings:
Idle
cpu 29-30
Chipset 42
Gpu 43
Load
cpu 43
Chipset 48-50
Gpu 57
antok86 said:MORE PICS OF THE VFD...what kind is that..i want to get one for my qpack
Soymilk said:rawr, i bought a refurbished warrantied as new case from frys and it didnt have any screws in iti looted my friend's stash, currently i have 5 mismatched screws holding down the motherboard and none holding the optical drive.
kezmo said:Game is hl2 lost cost, no idea what room temp is i live in england so its not overly hot![]()
Noise level is good, certainly alot quieter than my shuttle was![]()
What heatsink is that? You said 8000 but it isnt.
Very nice work dude
Do you know if that cooler will fit when running the Silverstone FX121 fan?
That is a fantastic looking build. Very clean! You have a good setup to go with it too.
I have only one request. Take some close up shots of how you installed the VFD so nicely behind those audio ports!.
