Dangman
Ninja Editor SuperMod
- Dec 15, 2005
I mentioned three silverstone cases. I assume you mean the Grandia?
Yup, the Grandia
Motherboard wise, it would help if you said what features you needed in a motherboard besides it being mATX.
What else should I specify other than being able to use the above components? If you specify DDR3 1600 there are only three boards I see to choose from. If instead you search for DDR3 1333 and above, ther are only 9 boards to choose from.
Oh, and if you have $100 to spare, upgrade the keyboard/mouse to one of these, they are priceless for a HTPC http://www.newegg.com/Product/Product.aspx?Item=N82E16823126039
Number of SATA ports needed, whether onboard video is needed, number of RAM slots needed, if RAID is needed, whether you need more than one PCI-E x16 slot, whether you'll be overclocking, etc. That's what we need specified.
Also note that DDR3 1600 RAM will work in motherboard with DDR3 1333 only motherboards. As been the case since the first SDRAM came out, RAM will downclock itself to the highest speed supported by the motherboard
I don't have a clue about any of that stuff. I can tell you that I have no plans for overclocking, crossfire, or anything like that. I'd consider myself luck and happy just to build the thing. I don't know about RAID, but If I want to backup my data, I would probably just use an external hard drive. Simpler, no? Onboard video would only be a benefit if it would be better at playing videos than the GPU picked out and/or extend the life of my GPU.
Most of the boards I looked at were practically identical anyways so I don't see how the above info would differentiate one board from another.
This is the weakest part of that setup: That particularly OCZ PSU is not of good quality as it is made by Sirtec.
Okay, scratch that.This is the weakest part of that setup: That particularly OCZ PSU is not of good quality as it is made by Sirtec.
The above info does indeed help differentiate one board from another. If you had answered that you had plans for overclocking, I would have gone with a mobo that had the SB750 southbridge as the SB750 is the better overclocking AMD southbridge. If you had answered crossfire, I would have looked for the 790GX chipset, etc, etc. So yes those answers did help.
Ok, and?All of the AMD micro-ATX boards I see have the same southbridge with the exception of the DFI LP JR 790GX-M3H5 AM3 AMD 790GX HDMI Micro ATX AMD Motherboard. It has an SB750 and specifies crossfire support.
Yeah, I shouldn't have suggested that one.In the future just avoid anything that has Fatal1ty on it.![]()
Ok, and?
Posted via [H] Mobile Device
My point is the south bridge only made that one board stand out. So how did those questions help you choose among the other eight?
Jeez never thought I had to explain the entire recommendation process:
Those questions made sure that you didn't have any special needs in a motherboard. You're right: yes to most of those questions would have only singled out one mobo, And that was the point dude: To see if you needed that DFI mobo
Ok, I started 12 mATX Socket AM3 motherboards:
http://www.newegg.com/Product/Produ...ption=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Yes they all have onboard video. So that question was a bit superfluous.
Ok, right off the bat, the Jetway and ECS are out since they're made by companies with bad track record. The refurb mobo is out since it's used. So that's 9 mobos left
Now since you didn't say you needed the features offered by the DFI, that's out. 8 Mobos left
I'm assuming that you wanted four RAM slots, that leaves out the MSI GF615M-P33. That's 7 mobos left.
I also asked how many SATA ports did you needed. If you had answered six, that would have left only two motherboards, an Asus and a DFI. However since you didn't answer, I assumed 5 SATA ports would be enough.
Since you didn't provide any more info like number of USB ports needed, number of eSATA ports needed, if firewire was needed, etc, I did what I always do when the client/op doesn't specify any other special features. So I Iooked for a CPU/mobo combo deal, found the Gigabyte mobo and Phenom II X4 945 CPU combo, and recommended that on the assumption that it would fit your needs since you didn't specify any other special feature.
Thank you. Without knowing your reasoning, I only had your word that it was better. I also wouldn't learn anything if you just gave me part #. So, of the 7 mobos you had left, there really wasn't anything different between them so you went with the one that came in a combo deal with the processor?
dannybui, you're putting too much effort into this, and you've already given the OP plenty of very good suggestions...
i would suggest the OP to do some more reading/googling to get a better idea of exactly what to build
I've tried reading/googling but the internet isn't very forthcoming with information. It takes a lot of digging just to find anything useful. Besides, I don't see why everyone is getting upset with a noobie asking questions. That's what noobies do. If you know of a good resource, point me in the right direction and I'll go read and research for a while.
I want to thank everyone for all of their help. I think I have a good idea of where to go from here and can help myself the rest of the way.
Indeed. Now go get a genmay subscription! lol.
I have a solution for you;
http://gizmodo.com/5403000/dell-zino-hd-230-mini-home-theater-pc
and done
