So, anyone else finish a build in their Osmi?
Just wanna look through to see if I can plan out my build process in it!
Look at the top comment on page 22...
Look at the top comment on page 22...![]()
I'm glad it arrived safely and you like it.
...most of the individual customers should receive their Osmi by the end of the week, unless there is delay by UPS.
Hi Gtek,
That's excellent! Is there still another batch going out next week? Haven't received an alert from UPS about a package shipment.
I got my Osmi yesterday! Transferred my system over to it and fried either my mobo or power supply...Tried everything I know how to do to isolate the problem. The fans turn on briefly then turn off.
Sadness. Still looks great though! Especially next to the white Xbone controller.
http://imgur.com/a/pk4ON
Oh no, that is terrible news. But I experienced this problem with few systems before and I usually got it running again... I assume you've tried to start your system without GPU, with single ram module without wired power button?
Update 2: I looked into the power switch and found a diagram of how it should have been wired. It was so simple.It's up and running now!
Doesn't the power button have NC, NO, C, + and - markings next to the terminals? (If it doesn't can someone post a picture of the underside?)
- NC: "Normally closed"
- NO: "Normally open"
- C: "Common"
So the correct way would be to wire C and NO to your mainboard, which way around doesn't really matter.
Tried building in my Osmi, and I cannot finish it.
First, I couldn't install my own 140mm fan since long screws (ones that allow you to pass both holes on the fan) were not provided, so I decided to keep the stock fan. Then, the extra VRMs on my Z87i-Deluxe on the top of the board (as well as on my Z87 Maximus Impact) doesn't allow me to install a 3.5" drive (which I decided to let go), then my LP cooler wouldn't fit because of the power switch (decided to stick with stock cooler).
But the last straw was the GPU bracket. If I wanted to fit my Nano in the Osmi, I would have to bend my bracket in order for it to fit like Claire had to do to her 970... I'm not bending a $650 card...
I love the look of this case and the build quality is impeccable! And i want to love this case in it's entirety, but I just can't build in it unfortunately.![]()
did you see the installation guide for GPU brackets on the previous page?
I did, but I'll try again to see if I can't manage to fit it in.
I'm really bummed at the moment, stayed up until 1am trying to build before I gave up.
PM see if I can help you.
PM'ed you!
Yeah, that's right. I'm just an idiot.
I'm pretty happy with my bent 970 ^^. But I don't intend to ever sell it (will recycle it in the living-room build when I upgrade), and it's clearly not the same price as the nano :/.
I understand it's frustrating :/.
Maybe you could just file the case so it would fit ? (pretty long with hand tools I guess but better than nothing).
Regarding the power switch, I think it's pretty standard, guess you could find a more compact one.
edit : exemple of small push button :
http://www.stein-dinse.biz/images/product_images/popup_images/300283119.jpg
Hey! Another thing you could consider is just removing the GPU bracket. Usually there are just some screws that hold it in place.
can anyone please confirm if a 120 AIO would work?
How about a slim 140mm radiator in place of the top fan![]()
My Osmi should arrive on Tuesday due to Canada customs holding my package hostage until I paid them and UPS $80.00 to release it.
I'm conflicted now. I wanted to order an XFX Nano and give the coil whine lottary another shot but if the Nano also has bracket issues....
We need a GPU comparability list for the Osmi or a quick case fix. I will also not void a $940 CAD video card warranty.
Comm, please let us know if you and G.tek worked anything out with your Nano.
G.tek, I'm sure you'll fix the GPU compatibility issues with the next batch but us early adopters should get instructions on fixing our early adopter cases if at all possible.
I suggest using 4 rubber washers which I supplied with Osmi (for HDD) to raise the whole upper part of the case, in order to increase the clearance. The problem is that they are only 1mm thick, which might not be enough. From the picture I got from commander_ is seems like the extra clearance needed for this different bracket design is 1-2mm.
https://imgur.com/a/P2zmy
Why exactly do you have to pay $80,- ??
I'm working on fix right now. I think I know how to do it, just waiting for feedback from commander...
