Phuncz
- Apr 12, 2009
I liked the first one more, at first. But after looking how complex it is, I liked the second one more.
So #2 gets another vote.
I like #2 also.
You should make a version with white panels, would look kinda like the turrets from Portal![]()
Have you verified whether #1 is actually manufacturable? I ask because those compound bends seem like they might not be possible with a press brake.
#2 is something I considered, but the small contact area with the ground can damage it, as you mention. I'm also unsure about relying totally on the strength of the material (rather than strength through structural design of the stand) to carry the weight of the case. I suppose if it's a thicker steel or even aluminum it may not be an issue.
So where are you going to put the 2.5" drives then? Putting them over the motherboard will kill very needed airflow.We're not going to mount hard drives over the GPU. Also moving down GPU would make problems with its installation.
The standard 46mm cooler is used on all retail LGA1150 CPUs at this point. The 30mm unit is used on the now-OEM-only "T" low-TDP SKUs. The big 75mm unit (P/N TS13A) is strictly high-end desktop (HEDT) (e.g. Haswell-E) at this point.Which reference cooler are you refering to? There's no such thing as one reference cooler, there is 30mm one, 46mm and like 60mm I think so the last one won't go for sure and also there's no cooler dimensions in cpu specs on ark.intel. Its a low profile case, it'll have limited amount of low profile cpu coolers you'll be able to install. Intel reference requires 82mm clearance from the motherboard surface to the outer wall.
Anyway we should fit 46mm cooler which I think is shipped with the low power LGA1150 processors like pentium and celeron.
I said it in ncase steambox topic - we've got a design we're okay with but its not good for a production yet because of the metal works cost so we need to optimize stuff.Hello, I like this form factor case, do you have an idea when it will be available?
If it's being cut on a laser, holes are much more expensive to do. I like holes for vents too but that would only be cost effective if it can be done with a CNC punch.
I think the diagonal slots conflictswith the rest of your design language have going and, frankly, looks like ass. Your original hex mesh and "optimal" slot designs have much, much better aesthetics.what do you think?
Definitely don't do the horizontal slots. The diagonal slots looks much nicer but still not particularly good looking IMHO. How optimal are holes as far as performance and manufacturing cost?
Speaking of cooling, here's a list of coolers I see most users trying and should be checked for fitment to put on the HCL:
- AMD stock
- Intel stock
- Noctua NH-L9a/NH-L9i
- Prolimatech Samuel 17 w/ Prolimatech Ultra Sleek Vortex 12
- Scythe Big Shuriken 2 Rev. B & Kodati
- Silverstone AR04/AR05/AR06
- Thermalright AXP-100
- Thermolab ITX30 & LP53
Any I'm missing that people would realistically be interested in?
As Aibohphobia said, we want to cut everything on a laser. Of course we could make it with the CNC punch/press, but it would rise the starting price by +50%?+100%? More? Design and mold of CNC stamp costs a lot. Our target is to make a case which is cheaper then most of Your CPUs (AMD's 8-core units starts below 200$). At this point, price between 100$ and 200$ can be reached, but how high it will be depends on our optimizations. We have signals that if we make it for 199$ it will be great. Some of You are saying 150$ is the best price. 99$ would be awesome. We have to check and calculate every option.
To understand how "laser-cutting price" works, You have to add material+number of interactions with material+time of interaction. By "interaction" i mean "start and stop" of the laser. Every hole is such a "start and stop". Before the optimizations from the last renders we had something like 450 holes in the material (in just one part). It means that laser had to "start and stop" 450 times. Now we have something like 90-100 holes in that part, thanks to this ventilation reorganization. We expect that, when the number of holes decreased from 450 to 100 we will get 25%-40% cheaper part. We have to re-calculate it with the laser-cutting company.
And about vent's performance: It depends of the area of the flow-surface and the type of the flow. The best type of the flow is a linear one. Every mm of the material on the path between cooler and the "external" air, makes the flow more turbulent. More turbulent flow equals lower cooler's performance and higher temperature of the cooled part. So the optimal version is to make holes in the case as big as the coolers we will have inOf course we can't do that, so we are searching for the best option. When we will get several designs of this ventilation holes, we will make flow simulations to check which is the best. At this point, our venting looks good from the performance side, but as some of You said, its "look" is far from good.
If You have some better ventilation options, we will try to check it, if they have a sense.
- AMD stock - APU(65W LP) & Heatpiped
- Intel stock 1150
Heads up that the Silverstone AR04, AR05, and AR06 are 23mm, 37mm, and 58mm, respectively, so only the AR04 and AR05 will work.As for the coolers - green for fitting, red for too big:
Looks like the same 50mm(?) cooler as the rest of the units.I can't find the 7850K boxed cooler dimensions. Anyone has it?
+1Your original hex mesh and "optimal" slot designs have much, much better aesthetics.
