MustRotate
- Aug 24, 2007
Hello all,
I am considering in upgrading my current seedbox(just 3x1TB HD103UJ).
Upgrade with the meaning of:
-addition of RAID controller(sataII,pciex x8,min 8ports)
-more harddrives(1TB or 1.5TB)
As I am a rather noobish person regarding to RAID I kindly ask for your advice about this.
The hardware will be used in a seedbox(utorrent and home fileserver). From what I have found a good solution for what I am looking for is the Adaptec Raid 5805 Kit card. That plus 8x HD154UI(Samsung green drives) for example.
Is it a good idea to put 5400rpm drives in a raid5 or 6 array that will run 24/7?
Should I consider reducing the number of drives and go for the raid class drives?
Can you please recommend me something that should fulfill all these requirements.
The current seedbox config is:
E4400,2x1gb ddr2-800,intel q965 mobo,3x1TB HD103UJ drives.
New mobo will be DFI UT X48 T2R, with CoolerMaster Z600 passive,4x1gb ddr2-800,Corsair Tx650 all in a Lian Li PC-A16B with two EX-34NB hard cages. Can I improve here something also?
