chrisf6969
- Oct 27, 2003
Ok, so not really a secret. But Overclocking is part art, & part science.
The science part is the methodically trying each variable one at a time to find what more or less stable. (VIP to write down each step) You need to find max ram clock / timings, max FSB, max CPU speed.
The art part is combining those variables (mutlipliers, ratios, timings, etc) to get the max stable OC.
Then its back to the science part to test which Overclock gives you the best results in your preffered games, apps, etc.
For true stability you need to test with dual prime 95 large TTF's or Orthos Beta (which automatically runs dual instances for you).
Anyway, not really a secret.... but if you look at the paper, each one of those lines represents a reboot with BIOS change. Then at each line sometimes I tested many different FSB's using SetFSB.
Having the right tools is important too.
CPU-Z, SetFSM, Memset, Speedfan, Coretemp, Orthos, etc..
