Bageland2000
- Jan 19, 2013
I have the Singularity Computers Protium D5 reservoir Pump Combo. I currently have three 120mm fans mounted to an EKWB radiator using the long screws that came with the radiator. I want to mount the reservoir using the bracket that it came with, but the extra width of the bracket means that the screws are too short to reach all the way through the fan holes and into the radiator. Surprisingly, the reservoir didn't come with screws. Is there standard screws that people use with added length to accommodate the mounting bracket?
