Scientists Predict Possible Ice Increase in Arctic
Zarathustra[H];1037667693 said:
This has to be some sort of bad joke.
That being said, it's posted on Fox News, which means the information is just about as reliable as the stuff from donaimhaber.com...
Your attacking the wrong messanger.
The story was carried by "NewsCore".
If you had read the story you would hae seen that.
So if Fox carries it, it becomes untrue?
OK...:confused:
Would you go eat your neightbor because he was using the wrong fertilizer? :confused: I could see the apes rising up and murdering the humans, but why would eatra terrestrials give a crap. If I told you that 3245 lightyears away there were aliens causing the atmosphere to go up a few degrees would you sudden have the urge to go nuke them?
Did you even read what these nuts are advocating?
Ya, there wachos, and maybe there the real aliens.
Yes I did. But again, why would aliens give a crap unless they lived here already, or were using the earth as a farm. :D
Real aliens aren't really like these people. They wouldn't write a silly report. Just pull out lasers and railguns and get shit done.
oxygen levels have never been this high before and CO2 levels have never been this low either (not on a small time scale but long term).
Nope. I don't know where you get your info from, but you are absolutely and totally wrong. I won't even bother with the rest since this one fact invalidates most everything else. CO2 levels haven't been higher in millions of years. It can be easily predicted with ice formations that date back those millions of years (you can extract information surprisingly accurately about atmospheric conditions in the past through ice).
Umm it is... http://en.wikipedia.org/wiki/Current_sea_level_rise
"Global average sea level rose at an average rate of around 1.8 mm per year over 1961 to 2003 and at an average rate of about 3.1 mm per year from 1993 to 2003."
Take notice: The arctic and antarctic regions were relatively free of ice in the 1500's (as evidenced by ship logs from the period, travelling through the north pole, etc...).
At the same time, mean sea level was...(drum role here)...the same as it is today! (as evidenced by St. Augustine being nearly at sea level its entire existence, from being founded in the early 1500's to now)
Conclusion: Global warming has little effect on sea level (because the ice is already displacing the water. Analogy: A full glass of ice water with ice cubes in it gets warm and the ice melts yet the water does not over fill the glass.
Now do you see why we think global warming alarmists are idiots?
now they have 10 more years to come up with awhole new way to scam the world into thinking global warming is the real deal.
Seriously, go with Climate Change. Dont blame it on Human resources, but work a mild angle of less pollution, less waste are good for us. Oh i forgot that doesnt generate $$$$$$$$$$$$$$$$$ for the scam artists behind global warming so nvm.
matchstick;1037662339The to the person that said "Seeing as how liquid water CONDENSES (gets smaller) when it freezes said:
They are a little off on the definition of condensing. They are applying one mechanisms name across to mechanisms.
Humidity, vapor...condenses into liquid.
Liquid water freezes into ice.
condense does not equal freeze, its two separate processes.
Zarathustra[H];1037661075 said:
Now, the reason this does not apply to global warming and sea level rises is simple. Not all ice floats freely on the surface. A lot is on land (Antarctica, Greenland, Siberia, Iceland to mention a few). other polar ice exists in places where the water is not that deep, so the ice actually rests on the sea bottom, meaning that it is not displacing as much water as it would if it were liquid.
If all the planets ice were in the form of floating ice bergs, then yes, we would not have to be that concerned about sea level rises. Problem is, it isn't
-1 >GCE (Gross conceptual error).
You are ignoring the fact that when the temperature rises, the rate of water ablation increases and more water is deposited in the atmosphere as humidity. This is redistributed across dry land as rain, which increases forrestation, which contains the water in plant life and such. It also moistens desert land, which will hold an immemse volume of the water.
In short, melting the above land ice will actually improve water supply to the rest of teh planet and the sea level stays roughly the same.
(teachers aren't teaching kids jack shit nowadays!)
Bull.
Yes, humidity will go up and more moisture will be trapped in plant life, but not nearly enough to offset melting icecaps. You forget that gaseous water expands in volume by more that 1600 times...
It may only contain a percent or so of the water. The rest will contribute to rising sea levels just like it has for decades (reference te 1.8mm and 2.3mm numbers posted earlier in this thread.)
2.3mm per yer doesn't sound that bad, but also factor in that it is rapidly accelerating. It seems to follow an exponential relationship, (similar to that of compund interest). Even so, this will probably be the burden of our childrens or grandchildrens generation, not ours. By the time they are old enough to do something about it, it may just be too late. You can't put the genie back in the bottle. That's just not right.
Zarathustra[H];1037668961 said:
Bull.
Ok, reference historical charts and logs of ships sailing in the arctic regions in the ice-less waters of the1500's. Then reference St. Augustine Florida founded AT seal level in the 1500's which is still AT sea level in present day.
Your science does not jive with reality. Bull right back at ya.
lol maybe you should actually try this experiment.
I'm always amazed at how many climate scientists there are on these forums.
Baloney! (Bologna?)
You are going to use 15th century cartography (their understanding of the world looking sortof like the below) as a basis for anything??? These people still believed the earth was flat. Their exploration probably never even went far enough north or south to diaxover ice (and if they did, they didn't map those areas)
They were probably sailing around just north of Denmark when they "weren't seeing ice)
Consider this, Swedish King Charles X defeated Fredrick III of Denmark by crossing te frozen belts (ocean strait between German mainland under Swedish control and Denmark) in the 1650s. He led his army of 9000 cavalry men and 3000 footsoldiers as well as artillery pieces across the frozen ocean to defeat the Danish who were forced to give un Scania (which remains a port of Sweden to this day) and all of Norway when they sued for peace.
Point being, in modern times you barely ever see any ice at all on the belts, even during the coldest part of the winter, yet back then it wa strong enough for armies to march accross it.
I don't know where you are reading this conspiracy theory crap, but it is complete bull.
Geological evidence shows icecaps existing at the poles going back even before the first established ice age, ~2.4 to 2.1 billion years ago.
Have you spoken to any geologists about these insane theories of yours? :p
Zarathustra[H];1037669036 said:
Baloney! (Bologna?)
No, I am using historical data...ships sailed right through the arctic regions (even the north plle back then. There was NO ICE there, and there was NO flooding. The same port cities that existed then still exist today, never lost or gained ground against the sea.
You should actually investigate history before making or even believing predictions.
Fine, then quote/link me to peer reviewed journals that reference these trips.
Quite frankly, it sounds like you watched one of those ridiculous History Channel specials that have ridiculous topics like "OMG did Leonardo Da Vinici invent the computer", "OMG Did the Knights Templar Settle North America", "OMG were Native Americans actually the decendants of Hebrew settlers" or "OMG where the mounds of latin america actually spaceports vuolt by aliens" or some other ridiculous half theory half nonsense like that.
Quite frankly, you seem to be speaking out of your ass.
OK...:confused:
Yes I did read it.
"NewsCore" is the internal wire service of NewsCorp, the parent company of Fox News (and also the company behind the phone hacking scandal in the UK)
It's all run by Rupert Murdoch, the biggest scumbag and propaganda mogul of the news world. Nothing, absolutely nothing that cones out of NewsCorp or any of it's subsidiaries (including Fox News) can be taken at face value. There is some serious agenda behind everything NewsCorp publishes/broadcasts.
Just in case I wasn't clear enough, those late night "Documentaries" on the History Channel tend to be more make believe than anything else.
Serious tenured historians laugh at that crap.
Actually, do me a favor...
...do us all a favor. Take this theory of yours to your local university history department.
Ask to speak to their renaissance expert and ask them what they think of your "ships sailed across the polar caps in the 1500's without encountering ice" theory.
Once they stop laughing, please tell us what they say.
It's hard to find many references to arctic sailing before the 1500's other than the vikings between the 700-1300 AD era. The vikings had pasture land settled in the 900s in Greenland, then global cooling starved them out and increased ice coverage through the 1500's.
Only 1100 years ago there were farms in greenland before it turned too cold to survive there. That plays really well with the whole global warming thing...maybe we can have successful farmland in greenland once again! Meanwhile, sea port cities of those years still exist today at the same sea level.
I'll have to look back through some real books to find the real history of shipping, as it seems to be erased or non-existant on the internet, as far as Google is concerned.
Here is about the closest I could come to finding online data on the early viking history: http://nsidc.org/seaice/exploration/arctic.html
History of Polar Exploration:
1594-1597
Willem Barents, after whom the Barents Sea is named, makes three voyages trying to find a Northeast Passage. He discovered Spitsbergen and sailed on to the Kara Sea.+ But on his last voyage in 1596, his ship became trapped by sea ice and he and his crew were forced to winter ashore on Novaya Zemlya. They built a cabin from the wrecked ship, and even though they had to battle hunger and scurvy, and the intense winter cold, they became the first West Europeans to winter in the high Arctic and survive. In June 1597, they set out for home in two open boats, but Barents soon died, although many of his men survived.
No ice in the 1500's eh? :rolleyes:
I invite you to read more about the ACTUAL history of polar exploration.
More bull.
Greenland was never effectively inhabitable. That's actually how it got it's name. Eric the Red returned to Iceland and tried to sell viking pioneers in Iceland on coming with him and settling there based on how lush and green it was (a bold faced lie) after which it got it's name, Greenland.
The inhospitable nature of Greenland is what drove Eriv the Red and his parties to explore further west and led to their discovery of what they called Vinland (translate as wine-land, another bold faced lie "it's warm enough there toucan grow wine").
This is what we - today - know as Newfoundland.
Justfor the record, there WAS actually a medeival warm period.
That being said, while warm forthe time, it was still cooler than the average temperature recorded during the 60s, which was significantly cooler than what we have today.
This is what the actual EPW government report says about that (link in my post above):
The National Academy of Sciences report reaffirmed the existence of the Medieval Warm Period
from about 900 AD to 1300 AD and the Little Ice Age from about 1500 to 1850. Both of these periods
occurred long before the invention of the SUV or human industrial activity could have possibly
impacted the Earth’s climate. In fact, scientists believe the Earth was warmer than today during the
Medieval Warm Period, when the Vikings grew crops in Greenland.
Climate alarmists have been attempting to erase the
inconvenient Medieval Warm Period from the Earth’s
climate history for at least a decade. David Deming, an
assistant professor at the University of Oklahoma’s College
of Geosciences, can testify first hand about this effort. Dr.
Deming was welcomed into the close-knit group of global
warming believers after he published a paper in 1995 that
noted some warming in the 20th century. Deming says he
was subsequently contacted by a prominent global warming
alarmist and told point blank “We have to get rid of the
Medieval Warm Period.” When the “Hockey Stick” first
appeared in 1998, it did just that.
You should actually read the report...it has a much different looking graph than you show.
Heres some epw.senate.gov sites that debunk it: Debunking Global Warming pdf
Great... Now youbare going to use politicians of all people tontrybto make your point?
What's next? An oil executive arguing how his company's products have nothing to do with it? Or maybe a lawyer to tell us all how guilty hos client is.
That is a report of made up crap to try to debunk something that is more or less scientifically proven for political gain.... :rolleyes:
My brain is starting to hurt.
In other words, more political sponge sponsored by think tanks bought and laid for by those who have something (money) to lose if government agreasively goes after greenhouse gas emissions. You'll javebto do better than this.
In a 2009 CNN study the following was observed:
Two questions were key: Have mean global temperatures risen compared to pre-1800s levels, and has human activity been a significant factor in changing mean global temperatures?
About 90 percent of the scientists agreed with the first question and 82 percent the second.
As time goes on these numbers only seem to grow.
My guess is that the few holdouts in the scientific community are either so blinded by their political ideologies that they are either willing to lie about scientific fundamentals or just don't see them or are paid "scientists" working for confessions think-tanks fully sponsored by the oil industry.
In the words of Farjad Manjoo of "True Enough" fame, everyone is entitled to their own opinions. Everyone is NOT entitled to their own facts.
The political right is notorious for playing fast and loose with the facts in order to make up shit that supports their political ideals. It needs to stop, and NOW.
I'll read it tomorrow. I promise ;)
You do realize that they can print whatever they want in these things right? They have none of the mandatory peer reviews or any other controls like the scientific journals do...
I fully expect it tone full of politically motivated FUD.
Meanwhile my brain is starting to hurt from the ignorance and stupidity displayed in this thread, and I have to work tomorrow. So I am going to have to call it a night.
you guys sure know a lot you should get published in a peer reviewed journal
Zarathustra[H];1037669131 said:
Yes I did read it.
I see, the scientists who said this never did.
Some people have a serious problem in beleiving the facts.
