MrWizard6600
- Jan 15, 2006
Does anyone else have a problem with it?
One of my first builds was a Hitachi drive in a P180B. I forgot to screw the drive cage back into the case when I picked it up. The cage slides out of the case and falls about six inches to the ground. Since I was a newbie I was wondering if the platters and everything inside had survived the fall (in actuallity they're usually designed well enough to withstand a five or six feet fall, as I found out on a friend of mines PC). Low and behold I find that the little "male" sata end on the drive had broken off inside the female cable. All of the contacts were dandy.
A little super glue later I've got the drive back up and running. Dr Spinright tells me my drives got perfect health. So the only thing lost from that 6" fall is a tiny bit of plastic.
I have since broken and repaired 3 more.
why dont they make these drives with sata connector that has a metal backing? Im tired of near-killing drives T,T
