xSystemFailurex
- Aug 15, 2004
Niceeeeeee gratz!
Yeah, for some reason I can't stop drooling at the first picture. It's just a video card... but... ooo... shiny...
Niceeeeeee gratz!
Yeah, I'm wondering what the bench would look like with a 2500k around 5ghz, I'll be interested to see for myself.
Am I the only one who liked the flat faced brick design? I thought the 6970 looked great, and practical too - so easy to butt ducting up against. Also, no more backplate.![]()
no because they are a bitch in crossfire since the bottom card in some setups sits perfectly flush to the top card. the way its designed now it shouldn't have as much of an issue in crossfire as it did with the 6970's.
Happy new Year.
The first three runs with card at defaults and then at 1125/1575
The 4th run is the only one that's overcocked, right? The others are at default stock speeds?
Grats! I will buy 4 of these cards when they are 375 a piece and not a moment sooner. Also lets see what that can do @ 5760x1200 if you have that ability.
Later I will post some benches at 5760x1080.
The card has 579 euro here in Greece.
I ordered by phone here http://www.plaisio.gr/
http://img638.imageshack.us/img638/4333/metroset.jpg
default
http://img846.imageshack.us/img846/306/metrodef.jpg
1125/1575
http://img94.imageshack.us/img94/6455/metrotez.jpg
Metro is one demanding bitch.
I think we can see better numbers.
http://vr-zone.com/articles/amd-radeon-hd-7970-voltage-mod--1.26ghz-flying-on-air/14398.html
I am waiting for bios that unlocks ccc limits and core voltage.
My new card is here.
AMD Radeon HD 7970 video card benchmark result - Intel Core i7-970 Processor ,ASUSTeK Computer INC. Rampage III Extreme score: P9088 3DMarks
"None the less, 1125 MHz on the core and 6300 MHz on the memory without any voltage tweaking has to be a new milestone all by itself. The advantage without added voltage is that the temperatures do not change that much, the noise levels remain okay and the power draw really isn't bad either."
http://www.guru3d.com/article/radeon-hd-7970-overclock-guide/18
Yes It's True.
Does the mismatched monitor connection tearing still occur in eyefinity like it did on Cayman? Please see my thread http://hardforum.com/showthread.php?t=1662914
I think this driver http://support.amd.com/us/kbarticles/Pages/Catalyst121Previewdriver.aspx solved this problem.
Tomorrow I will play with Asus bios that unlock core voltage.
I'm thinking 2 7970's in Crossfire would the be ideal setup with 2560x1600. Very few things should drop below 60fps maxed everything + a little AA. Metro 2033 might be a different bet but it runs like shit on everything it seems.
Nope my two 6990's Metro 2033 is like buttery smooth. Witcher2 with Uber that is another beast. I dont think that IBM has a super computer capable of witcher 2 Uber at more than 40fps.
that's some nice results zpaf, I see you have a i7 970.
I wonder if I get 1 or 2 7970 and overclock my amd x4 to ~4ghz if it becomes bottleneck for 1 or 2 7970?
OP, do you notice any screen tearing on your eyefinity setup? A lot of people have complained about it citing different output combination on the same card (2 HDMI + 1 DVI, etc).
It depend of what games you play and of course your resolution.
Some games are cpu bound other are gpu bound.
Your rig I see 5760x1080 so you have less possibility to bottleneck.
I had HD6970CF and played BF3 with i7-970 at defaults with no problems but with MW3 (a cpu bound game) I had to o/c my cpu to 3.8GHz for having > 95% gpu load.
All these things on eyefinity 3240x1920.
I think its better to buy one card see the behavior and then decide for the second.
Thank you, Did the card come with necesary accesorier to run eyefinity on 3 DVI displays?
My 2365wb only have DVI + VGA
I currently run Displayport to VGA adapter for eyefinity so left display is VGA.
PCI-E running at x16 1.1
Surely that is holding back some performance
Sapphire flashed with asus bios and with gpu tweak the limits gone.
http://img825.imageshack.us/img825/6996/asus2u.jpg
Its not easy at all.how easy was it to overclock to 1203/1900? did you have to increase voltage at all? how are your temps?
