Doubtful. That is one of the shortest exposures I have seen for BLB shot, like you are trying to play it down.
We really need a standard shot exposure when trying to compare BLB.
When I took a shot of my NEC when new. I used 1 full second. You used 1/8 of second.
Here is my one second shot:
http://img374.imageshack.us/img374/111/1secdarkaj3.jpg
I would suggest a standard shot might be something like this:
Monitor brightness 140 cd/m2 (Common recommendation that most monitors can reach).
Then something like ISO 100, F2.8, 1 Second exposure.
Or you can use this exposure calculator set to 20 LUX (Fireworks, Christmas lights) to match alternate settings:
http://www.calculator.org/calculate-online/photography/exposure.aspx
With max brightness, minimum brightness, long exposures, short exposures. These shots are meaningless for any kind of comparison. Make a standard shot then you have a basis for comparison.
Firstly, I've been a member of these boards for over 10 years and never have nor would I ever intentionally mislead anyone.
for its price there should be srgb emulation like on asus i mentioned or dell u2410 and then slightly wider gamut would be nice feature actually.
i think this monitor could use "digital vibrance" functionality as it expand not only blue but red and green also so decreasing it could remedy somewhat oversaturation
OLED is quite obsessed with 16:9, but there doesn't actually seem much rational behind it.
Someone should make a photo of the SA850 against a U2711, all U2711s I owned had crappy blacks in dark rooms because of the IPS white glow. I think those who are posting that IPS black levels are better haven't seen any 27" IPS display in a dark room.
Monitors aren't designed to be used in a dark room, and not having enough ambient lighting can also cause unnecessary eye strain. U2711 doesn't have fantastic contrast ratio anyway because it uses the older H-IPS technology.
Some people are willing to talk about "crappy blacks" (black bars) forgetting about the picture itself.
It does have an insane back, though A very hot running insane backlight...
What?
If someone says blacks they mean black level. If someone is talking about black bars they will say black bars.
It's no secret that IPS/PLS has worse black level than other technologies, caused primarily by lower contrast ratio.
Oh man I want this monitor, are there any other sizes available and what prices? I really favor Samsung for all my televisions and monitors but they have become expensive lately. They used to be a lot cheaper and good bang for the buck. I have been waiting for a good 1920x1200 monitor to come out from Samsung again. I am currently using the Samsung T240HD.
Both implementations are are comparably good. Differences:The only real sRGB emulation is offered by NEC PA series and possibly (no reliable reports so far) by similar Eizos.
Black level is not determined by contrast ratio.
Static CR is calculated after simple measurements of white and black (for a particular brightness of white). These simple measurements and calculation do not take into consideration the key factor - image stability from off axis view.
So real CR depends on good viewing angles & low black level.
PLS demonstrated absolutely fabulous black level 0.045 cd/2 in the test.
Please mark it as a "no secret" #2 because "no secret" #1 is 0.048 cd/m2 on H-IPS RGB LED that has been known for three years already.
S-PVA typical minimum is not lower than 0.1 cd/m2 (the Dell 2408 has 0.11), and it's only c-PVA that went as low as slightly <0.02 cd/m2.
I have never heard of the term 'real contrast ratio'
Hi, I've been following the threads for the SA850 for a while now. Right now I'm on the fence between this, the S24A850DW, and the Dell U2412M for $165 less.
From what I've read, this looks like a great monitor (unless you get a panel with bad back-light bleed). Aside from that, and the difference in the Dell AG coating vs the Samsung semi-gloss coating, does anyone have any thoughts about what this might offer over the U2412M in terms of picture quality and response times? I am new to the technical details of monitor comparison, and there is limited information about the SA580, so a more practical comparison would be very helpful.
Also, I know a lot of people in the U2412M thread said their panel had back-light bleed that settled to acceptable levels within a week. Could this monitor undergo a similar effect?
PVA offered unique advantages (and disadvantages) compared to IPS, and was cheaper to produce. PLS has no cost advantage over IPS, and no distinct advantages over IPS that PVA's had (such as better black levels). So tell me what would be the point for a 3rd party to go with PLS over IPS?
@albovin
There is no doubt that you are more of an expert on monitors than I am, but I am afraid I must take issue with you on this. I just haven't seen IPS to have the same black levels as PVA. I'm sure there are some high-priced exceptions, but that has been my experience. IPS may be a better technology overall, especially for color critical work, but blacks do not appear to be a strength to my eyes.
I would give Samsung a chance.In any event, the sRGB issues coupled with the backlight bleed would seem to rule out the SA850 from serious consideration.
You are most welcome.And I really appreciate the excellent review
Can it be calibrated to sRGB or is the color space rather too small?
Uncompensated color space mismatch.
Monitors must have either well approximated to sRGB color gamut or proper sRGB emulation.
Also there is a little chance that the 24" model differs from the 27" one.
I've been to many forums where users have commented on buying an SA850 to avoid LG's horrible coating.
Forgot to mention, I'm actually in Canada and I haven't seen 1 retailer that carries this monitor. Still would like to know if it lives up to the hype and if it is worth it... and if there is anything better around the same price point.
As Caesar said, "Alea iacta est."
I just made a command decision and ordered the S24A850DW for my wife from Buy.com.
It will be here tomorrow.
If I'm not happy, I will return it for the NEC PA24W-BK.
Thanks a lot for your brief report but all that was described word for word in the initial post - Samsung SA850 Test and Review.
Anyway thanks again for the confirmation.
The main and the only question to you, please: how does blue color (the blue sky) look on your SA850 in comparison with your second monitor?
Thank you.
