I'm shocked at just how underwhelming the s5 really is. Stupid people will still buy it though. And there are a lot of stupid people in the world....
the Z2 and the Z1 compact are great phones. I'd probably choose the compact between the two. The problem is US availability, and I especially doubt a CDMA version. I know sony made CDMA phones for China Mobile, but they have yet to do anything for Verizon or Sprint/softbank.I'm really intrigue with the Z2. I'm torn between Z2 and the new HTC One. I was gonna get S5 for the first time but w/ minor upgrade like iPhone 5 to 5S. Id rather wait for the Note 4 if I go samsung.
Totally agree, the S5 is a MASSIVE let down. Compared to the S4, it has to be the smallest upgrade between S series releases.
- S5 is still 1080p, with a worse PPI compared to the S4
- S5 is thicker than the S4, with only a minor 200mAh battery size difference
- S5 is heavier than the S4
- S5 is taller than the S4, with only .1" screen size difference
- S5 is based off Kit Kat 4.4, just like the S4 is today
- S5 is still plastic just like the S4, no cool new metal design, or at least HTC One X awesome polycarbonate ( plastic ) design
- S5 still has 2GB RAM
- Snapdragon 800 vs 600, is not night and day difference, especially if your not a gamer, it won't make you text faster, or get e-mails quicker.
Really, if you already own an unlocked S4, there is pretty much zero reason to upgrade to the S5, unless you win won for free.
I think the Sony Z2 is much better upgrade, or best new phone of 2014 so far. The Z2 has a 3,200mAh battery, is waterproof up to 6 feet, it has the newest Snapdragon 801 processor, the Z2 has 3GB RAM, Z2 has a better screen and higher PPI over the S5.
the Z2 and the Z2 mini are great phones. I'd probably choose the mini between the two. The problem is US availability, and I especially doubt a CDMA version. I know sony made CDMA phones for China Mobile, but they have yet to do anything for Verizon or Sprint/softbank yet.
The S5 has the Snapdragon 801 too, and as far as I've seen, the only difference between the 800 and the 801 is a slight bump in clock speed and support for my cell bands (I think).
Also, the Z2 is useless to most in the US. Sony needs to pull their head out of their ass's and do what it takes to get their phones in the US. 6 months after international launch and on the smallest US carrier (T-Mobile) doesn't count either.
Wait what? Unless the LTE bands suddenly changed, the Z2 supports pretty much all of them except for CDMA?
Not to thread jack this and turn it into a Xperia thread but I just wanted to point out that *some* Xperia Z2 cases on Amazon indicate a release date of March10th.
So IF this is coming to Verizon I would expect we hear more rumors percolating in the coming days.
Either way it is another dead heat really between the HTC One (2) the Z2 and the S5. But I would leap on the Z2 like a horny beagle.
There is a pretty massive difference between the S600 and S800. First and probably biggest is the gpu.
Is there any difference in everyday apps, I.e. Non games, though?
Galaxy S5 features Lucids battery saving techniques that increase battery life by 25%
http://www.sammobile.com/2014/02/28...-techniques-that-increase-battery-life-by-25/
if you read the Lucid documents, it saves power by throttling down the CPU, GPU, or both depending on type of application. Nothing on changing to monochrome or shutting services down... The number one reason why Samsung needs something like this is because of having bloat superiority compared to every one else.Yeah the power saving function where it reduces drain on the battery by going black and white and shutting down unnecessary services is simple genius.
The S4 had a 5" screen, up from 4.8" on the S3, but the S4 is thinner, narrower, and lighter, then the previous S3. Same with the Note 3 from the Note 2, the N3 has a larger screen than the Note 2, but the Note 3 is lighter, thinner, and narrower. Footprint size of the Note 3 is less than the Note 2. I thought that was cool.
But Samsung chucked that out the window with S5Phone is much bigger, for really no reason. The S5 has a very minor screen size increase, 5.1" now, up from just 5.0" on the S4, so really not much of a change there, and battery size, the S5 has 2,800mAh battery, compared to the 2,600mAh on the S4, again really not much of a difference. So why is the S5 so much bigger than the S4 ? The thin small bezels of the S4 that were cool are gone on the S5, the S5 looks wider, thicker, and bigger bezel, why ?
Samsung is just trying to keep the aspect ratio of a large bandaid.The thin small bezels of the S4 that were cool are gone on the S5, the S5 looks wider, thicker, and bigger bezel, why ?
I'm with you that it's a bit puzzling but having owned an s4 briefly that had significant hardware problems that were completely inexplicable I'm going to offer the following two-fold speculative theory:
The S5 is possibly beefier simply for sturdiness and more reliable long-term stability.
The S5 has a ridiculously bad-ass camera and a very high quality giant battery that need more room to accommodate and deserve more protection.
Another unrelated possibility is that Samsung is attempting to offer up a flagship phone that begs to have no case.
In fairness, I don't have a password lock on my phone so I could see how that could be extraordinarily annoying and a fingerprint scanner could help to alleviate that.
I do take issue with the much larger overall size of the S5 phone itself, compared to the previous model. I liked waht Samsung has been doing the last few years, upping the screen size, but making the new phone no bigger than the previous, or sometimes even a hair smaller, but with a bigger screen.
S4 = 136 x 69 x 7.9mm @ 130grams
S5 = 142 x 72.5 x 8.1mm @ 145grams
The phone is taller by 6mm but no one holds the phone from the top, it wont affect you. The width is 3.5 mm hardly going to notice it. That is less than 2mm extra bezel on each side really justification for claiming bezels are gone? If so then compare it to the competition.
The depth is listed as 8.1, once again are you really going to notice a 2mm thicker device? Even if you do AFAIK no one knows if that includes the camera or not. Because in the pictures the S5 camera protrudes more than the S4. This could mean they are both the same thickness but you just get more camera on the new one.
I don't know the explanation for this but I will point out that you make it out to be a big deal when yet you say the Z2 is a great phone when it is bigger in every regard. And heavier yet people are saying the S5 will get
I think the whole point is that the Note III was able to get a bigger screen and still slim down slightly....
Maybe peoples expectations were the same????
I'm (seemingly one of the few) still interested in the S5. .
Isn't there rumors that the QHD display S5 will be coming out in a few more months?
Or was that just a rumor?
I'd personally wait at least until the new iphone comes out (pretty sure the new One, Sony, and maybe even Nexus will be around the corner too).
idk, I am excited about this years innovation/style/software upgrades. Last year was too much hype hype hype....this year seems to be upgrade everything, overhaul, maybe even start from the bottom.
Report: Galaxy S5 announced early to hide lack of innovation, counter iPhone 5s
http://www.sammobile.com/2014/03/07...to-hide-lack-of-innovation-counter-iphone-5s/
According to one source, Samsung wanted to divert attention from the lack of innovation rumors and leaks leading up to the S5′s announcement suggested it would have features like a 2k display, 64-bit processor, and a metallic body, but except for a fingerprint scanner, none of the rumored and hyped features didnt make it into the final product. This supposedly prompted Samsung to announce the S5 at Mobile World Congress (MWC), likely because it didnt feel the new features and improvements in the fifth-generation Galaxy S warranted a dedicated event.
Another reason, apparently given by a Samsung executive, points at the positive reception Apples iPhone 5s received in Europe, a market where the Galaxy S series is extremely popular. I heard that it was necessary for our company to unveil the new version ahead of schedule, since the iPhone 5s got a better-than-expected response in Europe, which is the Galaxy S series stronghold.
