- Aug 29, 2010
What sorts of temps are you guys seeing with the 850 pro?
Are you talking about 850 or 950?
Okay thanks. Glad it is just a bug.its an error
Same here when I go into NVMe in the bios nothing shows up there which is maybe a part of the bug where it is only showing 10Gbps. Guessing this will require an update from Asus for the BIOS.can you tell me if your BIOS recognize the NVMe device please?
mine don't.
the option in this menu:
is disabled and grey out:
Another Asus flaw.
Can you boot windows with csm disabled for faster boot?
If I disable csm my system hang on boot
The Intel 750 was slower to boot than a G1 80 GB Intel SSD on at least 1 review.
still no idea why my test results are hit or miss.
I haven't change anything since installing, and it's gone from 1700-2500-1700.
I solved my boot speed problems, it was the CSM enabled.
I disabled CSM and the boot boost up from 60 seconds to 20, loading windows is yes, 4 seconds more or less.
The problem is that to boot with CSM disabled I need to detach my USB monitor otherwise the system hangs on boot.
In any case, wow, now the speed is awesome.
what is CSM?
Compatibility Support Module, if your hardware support full UEFI you can disable the CSM in bios.
With CSM disabled the system is much more faster recognizing all the peripherals.
so does the ASRock Z97 Extreme 6 good to turn CSM?
It depends, if alla your hardware support uefi, disable csm will help speeding up the boot.
The problem is that with csm disabled you should have some trouble with some USB connected at boot.
I can't connect my USB monitor for example or boot hang when csm is disabled.
I just ordered mine in The Netherlands (Europe), supposed to be shipping this week. EDIT: changed to next week![]()
have windows and sammy drivers?
Ya i have all the drivers installed, windows 10 shows NVME controller. I'm at a loss honestly.
I only have windows defender. Nothing else :/
Anyone with an x99 deluxe get this running at full speed on the m.2 slot? Every time I use the m.2 it links at half speed. Have it running on the pcie adapter sadly.
again that 10Gbps is an error. 2500*8=20Gbps
I think we are chatting on other forum too. I have the system in signature, really similar to your, as far as I have seen you have good performance and 10Gbps link, so what is the problem exactly?
No one here seen 20gbps on samsung magician software.
even got sammy drivers?
I honestly don't know. Try other benchmark programs and see if there is still an issue. It could be overheating. What are your temps?
Crystal Mark shows similar speeds. This is the smart info.
That's because it's listed as MB/s, not Gbps.
Yes, if I put the drive in the m.2 slot it links at 5 gbps. If I put it in the pcie adapter it links at 10 gpbs. This is regardless if there is a drive at pcie 5.
The speed literally halves in all benchmarks. I tried uninstalling the samsung driver, replacing it with the standard driver then swapping back etc etc. I also have to force the PCIE slot to gen3 in bios or I get the same issue even if it is in a pcie slot. It is quite frustrating. I will try to swap the OS to the 950 pro this weekend.
I hope not. I just bought my 950 Pro from Newegg yesterday ($199.99 -10% off discount code = $179.99) and it's supposed to be here Monday.X99 from Asus is a mess.
This will be my OS drive, replacing the XP941 I have in my X99-A now.
if you got the XP941 running fine I would be amazed to see the 950 PRO not work
It is the overclock, more specifically the baseclock. Bit-tech found the same issue:I reset my bios to default, and it seems to be running at full speed! Must have been something with my over clock? Now that it's working, to break it again.
The issue we had is worth drawing attention to since no faulty components were involved. We use an X99 motherboard for SSD testing, specifically the Asus Rampage V Extreme. However, when we originally tested the SSD 950 Pro drives both were being capped in performance. A later installation of a beta version of the Samsung Magician software revealed that the PCI-E link speed was being limited to 5Gbps, i.e. PCI-E Gen 2.0 instead of Gen 3.0, which the drives need to operate at full speed.
The problem turned out to be something as simple as our overclock settings. We use Corsair Vengeance LPX DDR4 modules rated at 2,800MHz, and we were using their built in XMP profile for our system's overclock. However, this automatically sets the base clock to 125MHz, which is a requirement when using high frequency memory (i.e. above 2,666MHz) on X99. However, this also affects the speed of other parts of the CPU, not just the cores, and one of those parts is the onboard PCI-E Gen 3.0 controller. In turn, in order to maintain PCI-E stability at this clock, our motherboard was downgrading the PCI-E interfaces to Gen 2.0. You can force the graphics slots back to Gen 3.0, but there's no such option for the M.2 slot, which makes sense since storage devices require perfect stability. We have not been able to confirm exactly how other motherboard manufacturers handle the situation, but it's probably safest to stick to 2,666MHz DDR4 on X99 when using a PCI-E 3.0 storage device. It should also not be a problem on Z170, where the PCI-E controller's clock is separate to the CPU BCLK.
