Ok, im sorry to have to do this to u all, but i have to ask, cus i havent seen much about one of these 3 monitors.
Right LCD newb, done a LOT of research, im gonna be gamin a lot on it, so :-
BenQ FP767 V2 17" TFT Monitor £ 245
- Contrast Ratio 500:1
- Brightness 260 cd/m2
- Response time 16 ms
- Analog input
- Stereo Speakers
OR
Viewsonic VX715 X series £ 287
- 25ms Response Time
- 300cd/m² Brightness
- 450:1 Contrast Ratio
- 1280x1024 Optimum Resolution
- 170° h, 170° v Viewing Angle
- DVI-D and RGB Input
- VESA 100 Compliant
- Supplied with DVI and Analog Cable
- 3 Year On Site Warranty
OR
Hyundai ImageQuest Q17+ £ 323
- 12ms response time
- 17 Inch Viewable SXGA LCD
- 0.264 mm pixel pitch
- 1280 x 1024 @ 75 Hz Max. Resolution
- 1280 x 1024 @ 60 Hz Recommended for use
- 2-port USB Hub with USB Cable
- Audio System: 2ch x 2w max, Earphone Jack
- Analog Input
- Digital/DVI Input
- Analog and DVI cables supplied
- TCO'03
- Comprehensive 3 year on-site warranty
Yes, i know most will probly say, either THE Q17+!! or tell me some other panel to confuse me, but my reasons are thus.
I wanted to just upgrade to 17", but findin CRTs that arent A) 22" and Expahuunsive! or B) About as good as those old flip books from the 20s, seems to be harder these days, maybe this area is bein taken by the LCD Gang.
SO, as you might think i didnt want to go nuts an keep lookin at reviews of monitors, an then findin one a liiiittle better, if ony i had that one, like we all do wi our PC bits lets face it. So i tried to just find a good LCD that i can use for games without it costin the earth ( the earth costs anythin over 280ish sqid t me )
Ive heard a lot of tell that most panels are about the same these days, seein as there arent many makers of the panels anyways, and the DVI vs Analog thing is not that big a deal if u have a good AGP card and a good analog monitor.
I tried to tell you all as much as i could so u dont waste ur hard earned free time here askin me more questions.
Thanks for any future help on this
- Analog input
- Stereo Speakers
OR
OR
- Analog Input
- Digital/DVI Input
- TCO'03
