They used the offsets in order to make the fans ramp up faster for the X chips (at least thats what they say) the newer version of Ryzen master software i believe removes this from the reading. the one that does not require the HPET.
Yeah, EB, your temps are below ambient so temp reporting is off there unless you have a magical chip that defies the laws of physics.What kind of cooler were you using?
That is 50c higher then my 1800x.
24c is 75f, not hard for ambient to get below that (though it would have to be near freezing for the cpu to be that cold, I guess, unless you have a really good cooler).
AMD FX 8350
When I think of it like that I am getting 6f above ambient with the zalman.
Should water be getting equal to ambient temps in a good loop?
6f above at idle6F above ambient at full load? I call BS ok that, regardless of what the motherboard reports. Either the offsets are wonky or you're looking at idle temp.
I am currently running 1700x and the same cooler while waiting on my Threadripper parts to arrive. I get about 25 idle and max 40 under full load.Just got around to this, I am using a Thermaltake Water 3.0 Ring RGB 240.
Just downloaded Prime95 and Aida64.
Is there an alternate way to check CPU temps?
ever get a cooling solution figured out?I am currently running 1700x and the same cooler while waiting on my Threadripper parts to arrive. I get about 25 idle and max 40 under full load.
I use coretemp and have a -15c offset and its damn near spot on with what mobo bios reports.
Figured out for what? I was full custom looping my 1700x until I took everything apart to get ready for 1950x build. I'm going to order an Xspc or Ek block for my 1950x.ever get a cooling solution figured out?
