Ryzen 5 1400 opinion
luisxd
I've been thinking on getting a Ryzen 5 1400 + AsRock B350M Pro 4 to replace my current rig (i5 4590 + Z87 MPower) cause i need more threads to render and compile, also need to downsize my rig. I can't go any further on to another Ryzen 5 cause my budget is low.
What do you think?, any experiences with the R5 1400 or the B350M PRO 4?
IMO, if you're going to make a change you should really pony up the extra $50 to get the Ryzen 5 1600. If you need more threads that's going to do a lot for you having 6/12 vs 4/4.
go Ryzen 1600 /w Wraith Spire 95W cooler included - Newegg for $220
AsRock B350M Pro 4 - Newegg for $80
To find a deal, you could also go to slickdeals.net and add "B350 motherboard" and "Ryzen 1600" to the deal alerts
Also check out Fry's and Microcenter
EDIT: also remember that there is no iGPU on Ryzen; if you're using that currently you will also need to pair with a discrete GPU
EDIT2: looks like you'll need to buy ram as your board is DDR3 and the Ryzen (or any new platform) is DDR4
If you really just want a smaller rig, buy Haswell miniITX motherboard.
Anything else would be a waste of money, unless you went with twice the budget.
I would watch out with Ryzen cpu over 4 cores on B350 motherboards most of them have questionable components for 24/7 use for 6 to 8 core unless you have cooling kit for the VRM and even then you have to be picky which motherboard.
I tried to grab one but their very rare and expensive now, specially the ones with Z chipset (if i stay at Haswell ill upgrade to a i5 k).
I read some good opinions about this board, i mean, i'm not gonna do LN2, just some casual OC to have fun :)
You mentioned originally wanting more threads for 'rendering and compiling'. You should check out benchmarks of the programs you use on other CPUs which have greater core/thread counts to determine how much improvement you might realize
Thanks for your replies guys. After reading some reviews i think i'll pass on the R5 1400 and save a little more to get a R5 1600.
Cheers :)
Problem is there are not enough R5 1400 benchmarks yet, just the same gaming and synthetic benchmarks all over the reviews on the web. That's why i came asking here.
You should be able to at least get an idea by looking at other 4-core/8-thread CPU's, 6-core/12-thread CPU's, etc. I think your plan is solid, save on up and keep researching!
I don't think it would be worth it for the 1400. Usually CPUs last a long time, might as well spend just a bit more and get the 1600.
My worries about the VRMs have been put to rest, then again if I kill everything its not really going to bother me as my Ryzen build is more of an experiment. Personally OP eat ramen a couple weeks and skip the 1400, buy a 1600...
