Anarchist4000
- Jun 10, 2001
I've been crunching the numbers, and I have a feeling they will be refreshing the entire line in short order, including a lot of dual chip parts that don't perform like we're accustomed to. With a coherent interconnect and the prefetching feature they should be able to make split chips act as one. Being on an interposer likely solves the traditional problems. It also seems like they might have nearly doubled the performance of the shader cores without even taking into account the move to FINFET. That would leave a 480X trading blows with a Fury.Should probably refer to them as Fiji XT and Pro since they could be rebranded/refreshed as the 490X and 490.
Anyways, the dual chip part should help with yields. If they're already using an interposer for HBM, sticking another die on there isn't too much more to ask. Efficiency wise, they will extensively be using one or more scalar processors within each CU for both compute and prefetching. These will rearrange waves to reduce/eliminate divergence issues and execute scalar code sections. SIMDs are variable sized during runtime with ALUs being disabled to save power. Throughput will reduce moderately as clocks rise to compensate. Theoretically cutting the SIMD in half and doubling clocks keeps the same throughput, however that's probably too much to ask. Likely an independent boost clock for SIMDs as well providing a large potential compute increase.
I've been assuming 1.3x for efficiency improvements(it may in fact exceed this slightly based on a research paper) and 1.5x for boost clocks(Nvidia currently manages 50%, so doesn't seem unreasonable). That would make each core nearly double a comparable core by today's standards. Throw in 60% less power from FINFET and you get the 2.5x perf/watt. It won't be any higher because the efficiency and boost numbers likely increase power consumption. They'd increase capacity, but lower perf/watt while in use.
460 = Cut Polaris 11 2GB GDDR5 1152cores 123mm2
460X = Cut Polaris 11 4GB GDDR5 1152cores 123mm2
470 = Polaris 11 4GB GDDR5 1280cores 123mm2
470X = Polaris 11 2GB HBM 1280cores 123mm2
480 = Cut Polaris 10 8GB GDDR5 2304cores 232mm2 Should be ~$200 and meet the VR spec
480X = Polaris 11x2 4GB HBM1 2560cores 246mm2 This should best a 390X and trade blows with Fiji "BAFFIN XT G5 4GB CHANNEL P/N 102-C98101-00 (FOC)"
480M = Polaris 10 4GB HBM1 2560cores 246mm2 Likely a mobile variant, although could be a discrete card.
490 = Cut Polaris 10 x2 8GB HBM 4608cores 464mm2
490X = Polaris 10 x2 8GB HBM 5120cores 464mm2
490M = Small Vega 8GB HBM2 3840cores ~350mm2
Fury = Big Vega 8GB HBM2 5760cores ~525mm2
FuryX = Dual Small Vega 16GB HBM2 7680cores ~700mm2 LMFAO if this fits, might be like the Pro Duo since HBM2 should be larger
FuryDuo = Dual Big Vega 32BM HBM2 11520cores ~1050mm2 This would be similar to Fury Pro Duo, can you say enthusiast part?
