ROG Swift PG35VQ
Discussion in 'Displays' started by Sparky, Nov 14, 2017.
  1. Sparky
    Sparky 2[H]4U
    3,125
    Mar 9, 2000
    Does this monitor have Asus GamePlus and where is it selling at? How long before it is selling if not selling currently?
  2. Sancus
    Sancus Gawd
    690
    Jun 1, 2013
    All this stuff(high res 144hz+ Nvidia HDR monitors) has been delayed to Q1/Q2 2018.
    Armenius likes this.
  3. tangoseal
    tangoseal [H]ardness Supreme
    5,994
    Dec 18, 2010
    I want that 35 va @ 200hz
  4. ronan_zj
    ronan_zj n00bie
    53
    Feb 27, 2009
    is VA better than IPS?
  5. Vega
    Vega [H]ardness Supreme
    5,576
    Oct 12, 2004
    The very fastest VA panels can only handle about 100-110 Hz or so. The pixel transitions on many colors are just terrible. Above 100-110 Hz, the black smear trailing really rears its head as the pixels cannot keep up with the refresh rate.
  6. Lastan010
    Lastan010 n00bie
    30
    Mar 2, 2017
    pixel speed is most likely improved then.
  7. Sparky
    Sparky 2[H]4U
    3,125
    Mar 9, 2000
    Will it have Asus Game Plus?
  8. Vega
    5,576
    Oct 12, 2004
    I would say if it did, it wouldn't be much. Slow transitions from black to white are inherent to VA technology. I mean look at the 200 Hz Z35 VA monitor. The black trailing is so bad the 200 Hz is basically unusable.
  9. Skott
    Skott 2[H]4U
    3,844
    Aug 12, 2006
    Same
  10. Sancus
    Sancus Gawd
    690
    Jun 1, 2013
    Maybe I'm just being naive but I hope that they wouldn't release a product with a panel that bad for its intended use, especially with Nvidia backing these as their flagship Gsync HDR displays. Repeating the Z35 mistake on a display that will probably cost $2000+ seems unbelievably stupid.
  11. Vega
    5,576
    Oct 12, 2004
    The only way I've seen VA usable for clear motion gaming is if you strobe the back-light to hide most of the trailing. That is what they did with the Eizo FG2421 and it actually worked really well. The 512 FALD zones could actually make this display scan the backlight and perform quite interestingly. But of course no G_Sync at that point. Pushing 3440x1440 at 200 FPS would be quite something.
  12. chenw
    chenw 2[H]4U
    3,917
    Oct 26, 2014
    What about the HG70? Does QLED improve the VA panel any?
  13. Drags
    Drags Gawd
    917
    Apr 26, 2005
    QLED is just a marketing term. It’s still the same panel tech underneath, it just has an additional Quantum Dot coating film applied to boost the colour gamut a bit. It has no impact on response times though sadly
  14. l88bastard
    l88bastard 2[H]4U
    2,359
    Oct 25, 2009
    Stupid is the display industries maiden name!
    Zinn likes this.
  15. Armenius
    Armenius [H]ardForum Junkie
    13,875
    Jan 28, 2014
    They're using refresh rate to sell the monitors. Usability at the max refresh rate is no concern to them. You can buy and use one, just limit the refresh rate to 100 Hz and you shouldn't experience any noticeable color issues.
  16. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    6,076
    Jun 13, 2003
  17. Sancus
    Sancus Gawd
    690
    Jun 1, 2013
    Honestly I'm wondering what real refresh rate this is gonna do... as a VA panel it's unlikely it does 200hz without major overshoot and ghosting problems, but as long as it's better than the ~100hz of current VA ultrawides I'm fine with it. Solid 144hz would be perfect.
    IdiotInCharge likes this.
  18. Betauser
    Betauser 2[H]4U
    3,640
    Jul 14, 2003
    Does anyone know when will this be released?
  19. Armenius
    13,875
    Jan 28, 2014
    At some point. You can never say with ASUS. It will just show up at retailers one day.
    Betauser likes this.
  20. Skott
    Skott 2[H]4U
    3,844
    Aug 12, 2006
    They showed it at CES this year. Rumor has it Q2 so Spring?
  21. Sparky
    Sparky 2[H]4U
    3,125
    Mar 9, 2000
  22. calikool
    calikool [H]ard|Gawd
    1,109
    Aug 9, 2006
