Right click slowness
Soarin
So for some reason a couple months ago windows 10 is having issues with slow right click. I have searched and found it to be a very vast problem and a lot of potential solutions but none have worked for me this far. I don't want to reinstall but will if I must.
Has anyone else experienced this?
I have removed Nvidia from the context menu and a few other options like libre office and foxit reader. Registry chnages but it still happens
WinRAR, winzip or any other utilities that like to add themselves to right-click?
maybe try creating a new user and see if it does it in there.
I will try the new user, the only thing added is display fusion. This all happened after an update a while back and I am not wanting to roll back months.
Tried the new user and it is working just fine. So I guess my fix is make a new user and delete this profile?
that or figure out whats loading in your existing user account.
So I ran some fixes with power shell dism and sfc, that did not fix it. I made a temp user and that worked. So I deleted my old profile and the issue came back when I moved files back over.
I am on the 1903 update as well, but running another update scan shows 2019-09 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4517211)
Update did not fix it.
did you install anything in the new user account or just copy files?
