Require help deciding on new mobo
PiNPOiNT
My motherboard is on its last legs. My current board is a asrock 939 dual sata 2.
My computer is crashing like crazy whenever i try and use the sata ports. It's been fine for years, but now its crashing all the time while using them, even after fresh installs, and with multiple different drives.
I'm looking to upgrade the motherboard with the latest and greatest, while will being able to keep all of my old components for at least a while.
Currently i have a BFG 7900 PCI-E video card
AMD 4800+ x2 cpu
2 gigs of OCZ dual channel platinum ram
I know that all new amd boards seem to be AM2 chipsets and that i can get a daughterboard to allow me to use my 939 chip in it.
A lot of the new boards are also DDR 2, can i use my DDR 1 memory in that? are they backwards compatible?
Also, im not interested in going SLI so that's not a requirement,
Which motherboards to you recommend for future upgradability while still being able to use my old components?
Thank you for your time and opinions.
sure that it isn't the other way around that you can get a daughter board to allow the use of an AM2 CPU in an Asrock 939?
No, AM2/AM2+ CPUs require DDR2
At this point, I'd either get a cheap replacement board off of the FS/FT section of the forum here (maybe $40-50). Or sell the good parts and buy new. A new motherboard/CPU/RAM can be had in AM2 for under $200.
Buy another Asrock until you are ready.
I am concerned, DDR2 is now cheap as dirt as DDR3 is starting to ramp up. I am not sure how much longer your stragety will remain viable however I completely understand the reluctance to dump equipment thats is perfectly good.
