replacement heatsink mount?
zrikz
So I just got back from a 8 day vacation to come home and see that my desktop only turns on for about 5 seconds.. opened it up and see that my heatsink is now resting on top of my video card.. awesome. Inspected the mount point and one of the plastic tabs that the heatsink mounts to managed to break off, on its own accord. Is it possible to buy just a replacement heatsink bracket / mount thing? I'm having trouble finding one on newegg.
asus m2n sli delux. (Am2) motherboard.
Those are hard to find. Best shot is to email Asus and see if they can send you a new one for a couple of bux.
Either that or see if someone has one lying around that they aren't using because they are using a different aftermarket cooler that doesn't use the bracket. I know I have some from the old s939's lying around, but no AM2.
shot asus an email, will let you know if I hear back any good news. Thanks for the responses everyone.
So no response from asus, going on 48+ hours. Can I buy a new motherboard and not have to reformat even if its not the same model / brand? If I have to buy one, might as well buy a motherboard that supports AM2+ or even AM3.
That or does anyone know of a heatsink that comes with a new mounting bracket?
Put a thread in the FS/FT section saying you want a bracket and will pay shipping. I'm sure someone "eventually" will help you out.
A whole lot cheaper than buying a whole new board...unless you're in the market for a new board.
Looks like it's called a Socket-AM2 Retention Bracket.
How 'bout this or check Google for other sources.
Pics are the same so I vote yes.
I went there first but got tired of wading thru the site.
You should just call Asus. They do have tech support and if anything they will call you back within 24 hours.
