Comixbooks
- Jun 7, 2008
Deer Hunting simulator
Mixed reviews on Steam mainly how the game runs and people can't link their account to the Rockstar client.
I mean if you you have a PC that is a few years old good luck.
I haven't tried msaa, but it appears to have the biggest performance impact according to some of the reviews.
Just picked this up direct via Rockstar (since that's how I have GTA V registered anyways)
Well, I used the settings this guy suggested:
(timestamped to the settings summary)
I'm now getting a silky smooth 60hz via rig in sig.
Def glad I waited a month to let Rockstar iron out the kinks etc.
Tonight, this is all I plan to do
EDIT @ night-time: Got all the way through Chapter 1.... Man, that was a long-ass prologue..
and?It's a long ass game
and?
should do 1080/med fineI bit the bullet and got it on Steam today. Guessing this will be the motivation I need to finally upgrade from my GPU.
Not really, it's a couple of skins and a gun or two, plus a quick robbery mission you'd never even notice was missing. There's also the boosts which make your cores drain 20% slower and such, which you can disable in-game. It's worth maybe $5. The usual price difference is $20, which is insane. I think on current sale it's $10.I'm finally gonna buy it since the sale is going on. Is the deluxe edition worth it?
I'm not sure how much more I can do really but I'm open to suggestions.
I like this a lot. Thank you for posting it and the timestamp was especially handy.
I'm playing the game at 4k on a single GTX 1080Ti with a G-sync monitor so I tried to be realistic since the beginning. G-sync has been buying me a lot of grace with some greedier settings in a few areas but I have used his and there were a few he has at high and went to medium (shadows and such.) I really don't want to dumb things down much more but I did buy myself a few more frames overall.
I'm on Nvidia driver 441.34 and the in-game benchmark now has me at:
Minimum FPS: 32
Maximum FPS: 58
Average FPS: 41
I discovered within a couple days of my original post that "Tree Tesselation" is a frame-eater (ie -5) so make sure that's off if it isn't already..
My g-sync monitor arrives in a couple of days and I didn't realize till after ordering that the fps range goes from 30-144 (instead of the usual 48 bs etc). So yeah, that's gonna be a real treat for me![]()
I get decent enough FPS w/ a 2080ti @ 4k.
