Strange bird
- Feb 19, 2021
You've fooled everyone again with your nonsense, always the same ones who start something stupid.
Strange Bird gonna Strange Bird.This is your thread, and this is what happens when you ask stupid questions with doing zero research.
Maybe do better?
that's why I opened the topic, to ask what the professionals adviseThis is your thread, and this is what happens when you ask stupid questions with doing zero research.
Maybe do better?
you just advised not 240 aiono prob!
Many AIO run for years with out issues?I’ve never liked AIO cooling solutions. The whole idea behind water cooling is to gain cooling efficiencies that are much higher than what can be had via air cooling, as well as to have greatly reduced noise, in a setup that’s both reliable and performs long term. AIO solutions typically use lines that are very thin/restrictive, employ sub-par materials and make use of lower quality internal components in order to maximize profits. They also tend to use aluminum instead of copper in their heat sinks/radiators to further reduce costs, and end up not really cooling all that more effectively than a middle of the road fan/air setup.
If you are going to water cool, my take has always been to do it properly with a custom loop that includes a quality pump, rad and block. Something that can be easily serviced and will hold up a long time.
AIO are a middle ground between a full custom loop and running on air. Not everyone wants to fiddle with building a custom loop and AIOs are a good alternative if you don't mind a bit more noise. The main downside to the AIOs is that they can't be scaled to have larger or more radiators or better water blocks. They are still great for a lot of people though, and IMO a better solution than air cooling. I personally prefer custom loops with much more radiator capacity than you get on a 360 AIO, but I would recommend going with an AIO for most people as it gets the job done well enough for them. Most AIOs run fine for many years, before they need to be swapped out and are fairly cheap and fast to replace.I’ve never liked AIO cooling solutions. The whole idea behind water cooling is to gain cooling efficiencies that are much higher than what can be had via air cooling, as well as to have greatly reduced noise, in a setup that’s both reliable and performs long term. AIO solutions typically use lines that are very thin/restrictive, employ sub-par materials and make use of lower quality internal components in order to maximize profits. They also tend to use aluminum instead of copper in their heat sinks/radiators to further reduce costs, and end up not really cooling all that more effectively than a middle of the road fan/air setup.
You are probably thinking of the older days.I’ve never liked AIO cooling solutions. The whole idea behind water cooling is to gain cooling efficiencies that are much higher than what can be had via air cooling, as well as to have greatly reduced noise, in a setup that’s both reliable and performs long term. AIO solutions typically use lines that are very thin/restrictive, employ sub-par materials and make use of lower quality internal components in order to maximize profits. They also tend to use aluminum instead of copper in their heat sinks/radiators to further reduce costs, and end up not really cooling all that more effectively than a middle of the road fan/air setup.
I quit using my 120x38s a few years ago. I still have them though..
FWIW my CPU gets as good temps or better than guys with a loop
And this thing is far from stock in terms of clocks and power.
FO, now go do your own research on what that means, google ityup, typical.
I think its still fine to get an AIO for aesthetic and space reasons.you just advised not 240 aio
I got so excited about AIO water cooling and in the end there are more reasons to be against it... I'll probably set the CPU to 3.86GHz and that's it, the Noctua junk will then be able to cool it down.
This is very innovative, for 161 euros (in a few days they raised the price to 171) you also get a 360mm aio cooling. You have perfect flow. I just don't know what the quality of that deepcool is and what about the spare parts/replacement if/when the aio breaks. It's a Chinese case and they usually have thin and weak sheet metal and the quality and control is sometimes bad.Nothing new or interesting.
Bottom spacing on rad you posted is restricting airflow to rad.
Mounting radiator in case as exhaust is actually beneficial to case cooling because it pulls air in and thru case to exhaust out thru radiator.
