Having read the review I know that i7 and C2Q can help you play at higher settings or give you more fps with quad CF but this does not necessarily mean having a 720 will be sufficient for weaker GPU setups.
what do you perceive could be the variable that prevents a 720 from adequately feeding a less powerful setup like 4890's in cf? if the variable is resolution, then you are absolutely correct, as we've all come to understand that lowering resolution puts greater onus on the cpu to do the rendering. perhaps a game that requires intensive cpu physics? dual 4870x2's or dual gtx295's are ravenous gpu setups where there's no such thing as enough cpu speed even at 25x16, but for dual gpu setups like 4890 cf or even gtx260 192 sli the resolution threshold is still 25x16, so the disparity between cpus should remain the same.
